Sym dd50 build!!
Madman
Sym dd50 build!!
Post by Madman »
So I want to start this build thread as I'm finally going to rebuild my engine with a BBK from kn kikaku which I have on order and will get in a week or so.
I'm going to need advice as I go on this one! I'm going to do it all myself and am going to port out the boost port and the intake port as well.
Parts I have now include.
Yws v8 pipe
Oko 21mm
Ct intake 4 petal reeds
Kitako Koso variator
Clutch springs
Center spring
Parts on order
48mm 74.9cc BBK kn kitako including head
Oil pump plug
Oil seals for crank
Crank bearings
So my first question is should I get a new crank it has about 10000miles?
Thanks.
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
veedubh20
Re: Sym dd50 build!!
Post by veedubh20 »
change the crank. dont worry about crank going breaks...
all new parts seals, bearing and bore.
paulpauly7
Post by paulpauly7 »
theres some nice stuffer cranks on yahoo auctions for a good price
Downsouthdio
Post by Downsouthdio »
Might as well if your going to have the block split :2thumbs:
Honda super dio
Corsa
26mm
Sparrow
Madman
Sym dd50 build!!
Post by Madman »
This is how it kinda started,has a chinese pipe there
Had some damage so I fixed it up and sprayed it blue.
Now it's gonna get the engine done!!
If I'm putting in a crank should I go for a mini stroker or just keep it stock?
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
kingkamehameha
Post by kingkamehameha »
Get the malossi crank
Dio89Elite
Post by Dio89Elite »
If you have the funds, "DO IT!" :thumbwink:
after all the block will be split anyway and everything else is going to be new too = FRESH! :2thumbs:
May I ask what blue paint and method did you use? Did you do it yourself? It looks great!
veedubh20
Post by veedubh20 »
get a stock stroke crank 41.4mm malossi, honda oem or rumia with thicker conrod.
dont get mini stroker crank!!!!
Madman
Sym dd50 build!!
Post by Madman »
Dio89Elite wrote:May I ask what blue paint and method did you use? Did you do it yourself? It looks great!
Well I got some spray paint it was car paint and decanted it into jars. Then I airbrushed it on about 3-4 coats sanding between coats a little, messed up a couple of times with runs, sanded them out and recoated. Then gave it three coats of lacquer clear coat sanded it back and polished it out, took about 5 days couple of hours a day.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Sym dd50 build!!
Post by Madman »
veedubh20 wrote:get a stock stroke crank 41.4mm malossi, honda oem or rumia with thicker conrod.
yeah I think I'll just get some bearings and inspect my crank when its out may be fine and I'll save some money. Looking around and some cranks are expensive, went to the shop to price out original Honda and sym cranks and they were about 150000¥ or 180$ about! I'll be saving that!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Sym dd50 build!!
Post by Madman »
Some picks before I tear it apart for the rebuild!
Looking forward to this!!
Still waiting on parts.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
paulpauly7
where in japan do you live?
where did you buy that pipe?
how is it compared to the chinese chamber pipe?
Madman
Sym dd50 build!!
Post by Madman »
Live in Tokyo, bought the pipe from "kn kikaku"
The Chinese pipe was good at high revs and gave a couple of miles more but at low revs it was really boggy even when tuned well, the Chinese one stated on the site where I bought it that it is not suitable for BBK so I switched over before doing the bbk! Also Chinese pipe was a little louder.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
veedubh20
Post by veedubh20 »
Im selling my rumia crank on ebay.. sn jpnscooter..
Madman
Sym dd50 build!!
Post by Madman »
veedubh20 wrote:
Madman wrote:
I saw that but it only ships to USA and I live in Japan, so I'll get one from Taiwan or china or just inspect mine, have no problems with it now so it should be fine!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
