stage 3 spree. need a pipe!!!
SuprasNsprees
Re: stage 3 spree. need a pipe!!!
Post by SuprasNsprees »
eliteguy50 wrote:I don't know you called them but its only 7:40am in HI.
ive called 3 places. 2 were in FL (moped hospital & MRP), and one was local. the 2 shops in FL dont seem to have time to talk to me
'80 Puch Magnum MKII
'78 PA50 Hobbit
Downsouthdio
Post by Downsouthdio »
What exactly are you looking for? I can swing by when i get off.. They bs over there.. Sometimes you have to walk up in there
Honda super dio
Corsa
26mm
Sparrow
Downsouthdio
The pipe thats right.. Ill swing by and ask them
Honda super dio
Corsa
26mm
Sparrow
Downsouthdio
A guy i know here took a lx header and put a tecnigas header back an made it work for his af05
Honda super dio
Corsa
26mm
Sparrow
SuprasNsprees
Downsouthdio wrote:A guy i know here took a lx header and put a tecnigas header back an made it work for his af05
im not against fabricating something to a header. i'm just trying to find something first
thanks for looking out man!
'78 PA50 Hobbit
Downsouthdio
Let me see what i can find out
Honda super dio
Corsa
26mm
Sparrow
SuprasNsprees
you're the man! specify that its a 67cc if you can,please
'78 PA50 Hobbit
Downsouthdio
No prob bro.. What bbk do you have? Moped hospital sells the 66cc airsal aluminum kit. Pretty decent price too
Honda super dio
Corsa
26mm
Sparrow
Post by swimmingfree »
did you try gutting the other expipe and putting a bigger tipp on it ????
thank you kingkamehameha ive never seen this ... and your a grate dog for diggen this up thank you ... :smile:
Downsouthdio
They only have them for the af16's.. My bad bro .. Thought they might have had something
Honda super dio
Corsa
26mm
Sparrow
SuprasNsprees
swimmingfree wrote:did you try gutting the other expipe and putting a bigger tipp on it ????
i haven't only because i'm not sure where the restriction is in the Iowa pipe that i have. there's no washer visible, but when i changed the pipe out for a non-Iowa pipe it was clear there's something not visible that held it back
Downsouthdio wrote:No prob bro.. What bbk do you have? Moped hospital sells the 66cc airsal aluminum kit. Pretty decent price too
i have the taz kit. idk who makes it for him other than the piston being an RIK
'78 PA50 Hobbit
dose the head pipe look the same on the 2 pipe ??? if so then it wood have to be in side of it mufler i wood think??
kingkamehameha
Post by kingkamehameha »
You guys have been here for how long and you have never bothered to look through the advanced tech docs? There is so much info on this site all you have to do is use the search feature and browse through the old tech docs. Jennings is two stroke jesus man read up
Downsouthdio
KIng hows the spree ridin?
Honda super dio
Corsa
26mm
Sparrow
no one have ever said im the smart one on here and if thay did thay lyed to you :smile:
