tail-light fades away at start-up
andyf80
Post by andyf80 »
Hi guys,
Fantastic site...first time poster here.
I have a 1984 spree that among other problems I can not get the tail light to stay lit.
When I turn the key on the ignition to the 'on' position the tail/brake light comes on pretty bright and then quickly fades and won't come back on again nor will the brake lights when I hit the brakes. Oh, also the front blikers will not light up or work.
I wondered if anyone had any ideas for me....would a fuse be suspect for something like this?
Thanks in advance for any help you can give!
myhonda
Post by myhonda »
ok the tail light is a bad ground. the blinkers probly the relay. do u hear a clicking noise when u turn the blinkers on. if not its the relay
andyf80
Post by andyf80 »
myhonda wrote:ok the tail light is a bad ground. the blinkers probly the relay. do u hear a clicking noise when u turn the blinkers on. if not its the relay
Thank you....I will look for that ground today. I don't hear a clicking sound with the blinkers on.....I know the clicker works as I tried it by touching it to the battery.
Thanks
MySpree
Post by MySpree »
i have a relay if u neeed one.
andyf80
Post by andyf80 »
MySpree wrote:i have a relay if u neeed one.
Say.....you guys are great! First I have to find my relay :) how can I go about testing to see if my relay is bad/good?
I have a volt meter...
If I by-pass my relay should by blinkers stay lit....or at least light up?
MySpree
Post by MySpree »
try jumping it off a car batt if when u put the blinker on it clicks. then its good. its a little black bock on the right side of the battery box. it has four wired mettn n to a single connection. you can mis it.
andyf80
Post by andyf80 »
MySpree wrote:try jumping it off a car batt if when u put the blinker on it clicks. then its good. its a little black bock on the right side of the battery box. it has four wired mettn n to a single connection. you can mis it.
Thanks Myspree,
huge help....i'll give it a shot.
prattj1
Post by prattj1 »
I had to take apart and clean my turn signal selector to get the lights to work. once you clean all of the contacts put a little dielectric grease in there and you wont have to deal with it for another 22 yearsIt took about 30 minutes total.
MySpree
Post by MySpree »
yea, i jus tclean em and put them together. i go every year with a voltimiter cheackng the resistance on my peds, makeing sure there good.
