Re: Need a quick help For my friends Honda Elite .
Oh man you did a nice job !! That is how I want my plastic to look like just like yours. I am going to try the same thing you used hopefully I will come with a good result.
Re: tip on painting
how long to I have to wait before I apply the dupli color primer filler on the repair area ? Also should I apply the primer filler on all the panel or just the repair area?
I had used the fiberglass repair and Bondo for my filler.
Re: Honda elite and spree body rebuild
couple more things to go before I can paint .
Yep I found why th speedometer is not working my wire insinde the cable is brokedun rite wrote:glad you got it going. for speedo you need to check the cable, possible stripped gears on the wheel end. hard to say. Hope you have good luck with that carb.
Hey guys what is the Difference between honda elite 1998 sa50p and 1988 sa50 ?
Also what is the best oil to used on it ? Do I need to buy 2 steppe engine oils ? Thanks
Some updates on my spree .
Yesterday I got most of my spree panels paint with Rustorleum Enamel paint.Did a pretty good job. I am waiting to apply the Clear coat may be Saturday . Want to give it time to dry.After clear coat . I am going to let it sit before I can sand and polish .
I steel can't can't decide on the color for My 1998 Sa50p Honda elite.
looking good.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
Thanks It is not done yet haven't apply the clear coat .
Check this out Bonesv I used the kind or paint that you required to me on my elite . Man those parts look so beautiful.
- IMG_1935 (480x640).jpg (71.45 KiB) Viewed 5408 times
- IMG_1926 (480x640).jpg (67.75 KiB) Viewed 5408 times
- IMG_1931 (480x640).jpg (67.71 KiB) Viewed 5408 times
Duke250 wrote:Check this out Bonesv I used the kind or paint that you required to me on my elite . Man those parts look so beautiful.
like the satin black!
what exactly did you do and use please?
(I will be painting my aero in rat rod fashion and want a satin or flat black color)
'86 Aero 50 (NB50)
'01 Yamaha Jog Nextzone
Man, those look great! Yea, there's alot to be said for that paint. It's the hot ticket!
You did a real nice job.
Keep posting the results for us on the rest of it.
i used the duplicolor trim paint to prime it and then the bumper coat for my finish. Also they are flat black color no gloss in them . You can get those paint at an Auto parts store. Just apply those paints like the instruction say and it will come out nice with no runs.
- IMG_1939 (640x480).jpg (61.76 KiB) Viewed 5400 times
- IMG_1940 (640x480).jpg (54.73 KiB) Viewed 5400 times
forget about rustorleum spray paint.
have some updates on my Elite. I had all my plastic painted that satin black and now today I got most of my panels done too. Now I've used Duplicolor on my Honda elite and Rustorleum on Spree. I did that because i want to compare both together. Now I found out that Rustorleum if you take your time it can get the job done but take a long time to dry. By the time it is taking to dry it easy for anything to damage your work. Now with Duplicolor that thing dry so quick and buy the time something will go wrong with it . Duplicolor will be on its way to dry . Now with the can I like the way the duplicolor paint shoot the paint . It is easy to apply then rustorleum paint . Those are what my panels look like . I haven't apply the clear coat yet.
- IMG_1949 (480x640).jpg (63 KiB) Viewed 5382 times
- IMG_1944 (640x480).jpg (70.96 KiB) Viewed 5382 times
- That is the ground coat pic
- IMG_1942 (480x640).jpg (72.12 KiB) Viewed 5382 times
now the transparent coat.
- IMG_1974 (640x480).jpg (65.65 KiB) Viewed 5382 times
- IMG_1960 (480x640).jpg (49.48 KiB) Viewed 5382 times
- IMG_1956 (480x640).jpg (56.69 KiB) Viewed 5382 times
all most satisfied !!!!!
one down still have three to go . I haven't applied the wax yet
- IMG_0121 (640x480) (2).jpg (62.76 KiB) Viewed 5367 times
- IMG_0120 (640x480).jpg (65.41 KiB) Viewed 5367 times
- IMG_0119 (640x480) (2).jpg (67.37 KiB) Viewed 5367 times
