Tools needed to fix anything on a 50cc honda scooter.
Re: Ultimate Tool Box for a Honda scooter.
True. I only work on my own.
When it's getting late and I'm tired and I start a beer I just fade, and I go to bed. Things that were real difficult last night are easy in the morning.
Industrial gloves are also good. Disposable gloves don't hold up to chemical use.
- swimmingfree
a wash tank big a nuff to put the hole motor in for cleaning ...
Spark plugs. Lots of spark plugs.
- Red Eft Performance
Pressure tester.
Red Eft Performance
View products click => Here
...what kind of pressure are you suggesting needs testing ??Red Eft Performance wrote:Pressure tester.
Already mentioned is compression tester and air gauge....
- fastplastic
i suggest a gun... so if it * you off you can shoot it
I like my magnet grabber
Wire puller
Assortment of brushes
Assortment of sandpaper
Head light lamp
Adjustable work light
Magnet nut holder
Wrist magent holder
Shrink tube
Soldering iron
Butt connectors assorted
Ball point pen
Rubber band
Paper clip
Duct tape
Pantyhose
Wire puller
Head light lamp
Magnet nut holder
Wrist magent holder
Shrink tube
Soldering iron
Ball point pen
Rubber band
Paper clip
Duct tape
Pantyhose
A pressure test is a way to check a motor for air leaks. It checks all gaskets head gasket, base gasket, intake manifold gaskets, crank seals, case halfs ect. probably the most under rated tool on this forum that would probably eliminate alot of the tuning problems people are having. This tool can be made all kinds of different ways.motormike wrote:...what kind of pressure are you suggesting needs testing ??Red Eft Performance wrote:Pressure tester.
Already mentioned is compression tester and air gauge....![]()
You may not think that you need one but trust me once you start using one and you start finding all kinds of leaks you never thought were there you wont want to be with out one.
Here is one example http://www.youtube.com/watch?v=zdq7NRcUIp8
Red Eft Performance
It is called a case or crankcase pressure and vacuum tester.
Yes indeed, crankcase pressure...the video helped understand this testing procedure clearly...thanx Red EFT...
I've used the coolant system tester many times for checking autos. ....
need a sign on my back....CAUTION: STUDENT 2T TUNER
compression test is good tool!
dont need common honda bolt and nuts
dont need leak down test!
all the block inspection. I go by vision
see there got leaking oil on gasket ( head and base) or airleak ( vaccum leak ) crank seals leaks
for the transmission seal. look at clutch shaft seal, tranny gasket and main axle seal when remove wheel off.
- Trafficjamz
Re: Tools needed to fix anything on a 50cc honda scooter.
Updated first post
This list is for TOOLS only
Disposable/consumable things like tape, WD40,fuses and gloves are a good idea, but did not make my list.
I love my slide hammer, they can perform magic, although only used it once on a scooter
Impact driver and hammer. Long punch or rod (tap loose the belt cover from exhaust side).
