I have a few friends that work at various shops equipped with dynos and i'd like to see where my bore/pipe combo is making peak power and such.
From what i've read, locking the variator takes the trans shifting out of the equation and gives a more traditional dyno plot.
Anyone done this?
How do you lock the variator for use on a chassis dyno?
2000 Elite: oko 24 (45/135), corsa, pg short, keli vari, 8.44 secondaries = 71mph gps
1995 Jog
2004 Malaguti F15
2007 Ducati Monster S4r
1995 Jog
2004 Malaguti F15
Re: How do you lock the variator for use on a chassis dyno?
You can't lock the variator, but putting the heaviest weights possible in it will make it shift faster. Or you can manufacture something the wedges the variator in the fully extended position.
Or you use a proper small engine dyno instead of a chasis dyno. The one I had came with fixed sheaves for cranks of different diameters.
