Tools needed to fix anything on a 50cc honda scooter.
Re: Tools needed to fix anything on a 50cc honda scooter.
Post by swimmingfree »
tap and die set is nice to have ..
Breezy wrote:I love my slide hammer, they can perform magic, although only used it once on a scooter
how did you use this on a scooter?
evilone
Post by evilone »
Trafficjamz wrote:how did you use this on a scooter?
To get the crank out after splitting the cases.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Breezy
Post by Breezy »
Maybe, but I didnt use it for that.
When I was replacing the bearings in the final drive unit/gearbox (a sealed tye of bearing), one was so naft that the inner race popped out and the outer race was left behind, it was in a blind whole so I could not tap it out with a punch, so I very carefully welded a big washer to it and stuck the slide hammer on it, it came out easy as...
pulling crank pulleys off car engines the slide hammer is king, causes less damage, they are awesome at pulling out cv joints and beam axels too, better than using pry bars and screw type puller kits...
Post by eliteguy50 »
X2 on the final drive. Also handy for stuck rims. The blind hole should not be a sealed bearing.
Breezy
Post by Breezy »
eliteguy50 wrote:X2 on the final drive. Also handy for stuck rims. The blind hole should not be a sealed bearing.
you are right, I just suck at explaining things, I meant a sealed type as its not a tapper type with a separate race. the actual bearing replacements I had were sealed bearings with the seals removed, if you catch my drift.......
If you pulled the seals, they are the same.
New tool idea, dental style picks for pulling seals and o-rings out of grooves.
