OKO 24mm Carb Question
ragtop89
Post by ragtop89 »
What is that small tube for on the air filter side? Should I adjust it open? never really noticed anything going through it.
http://www.treatland.tv/OKO-24mm-carbur ... -metal.htm
83' Aero NH80
86' Yamaha Riva 125Z
paulpauly7
Re: OKO 24mm Carb Question
Post by paulpauly7 »
thats the power jet you will wanna block this off
dv/dt
Post by dv/dt »
paulpauly7 wrote:thats the power jet you will wanna block this off
+1. Shove a BB in the plastic tube.
2000 Elite: oko 24 (45/135), corsa, pg short, keli vari, 8.44 secondaries = 71mph gps
1995 Jog
2004 Malaguti F15
2007 Ducati Monster S4r
ragtop89
Post by ragtop89 »
Thanks for the info. What does it do exactly? Been running it unblocked all week.
83' Aero NH80
dv/dt
Post by dv/dt »
It acts as yet another jet that only starts working at some unknown airflow rate.
It makes tuning the scoot a PITA.
1995 Jog
2004 Malaguti F15
ragtop89
Post by ragtop89 »
Alrighty, I'll run it blocked this week and see what happens. :thumbwink:
83' Aero NH80
It acts like a power valve in the Holley carbs. Only problem is 2 strokes don't respond well to being run super lean in the mid-range. So yeah plug it. I use a BB at each end of the hose, but I get carried away sometimes.
down south stroker
Post by down south stroker »
i just left mine alone havent had any problems yet lol
2001 elite sr
72cc corsa
boost port matched
ruima mini stroker
ct mani
6.5:1 primarys
24oko
polini kevlar
72 scorpion
malossi cdi
3.50 rear tire (305 cuzz!)
70 mph
It can make the mid range run very lean if you are not real careful with your needle adjustment. So instead of seizing you engine at WOT, you will do it while cruising.
bakaracer
Post by bakaracer »
down south stroker wrote:i just left mine alone havent had any problems yet lol
then I highly doubt your doing 70mph with the hose still hooked up and using 6.1to1 gears and a ruima mini stroke crank
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Downsouthdio
Post by Downsouthdio »
Hes deffinitly doing 70mph.. Bike had been setup that way for over a year.. And does 70 and could go more
Honda super dio
Corsa
26mm
Sparrow
Downsouthdio
69.9 to b exact.. Verified multiple times.. Slow take off, plenty top end
Honda super dio
Corsa
26mm
Sparrow
down south stroker
like my buddy stated been verified plenty times on accurate gps . all stock jets in the carb also if u wanna believe that lol i will post gps readin soon
2001 elite sr
72cc corsa
boost port matched
ruima mini stroker
ct mani
6.5:1 primarys
24oko
polini kevlar
72 scorpion
malossi cdi
70 mph
down south stroker
i have a cammed c6 vette it does 200mph so wen ur ready baka come to the keyssssssss bubbba!!!!
2001 elite sr
72cc corsa
boost port matched
ruima mini stroker
ct mani
6.5:1 primarys
24oko
polini kevlar
72 scorpion
malossi cdi
70 mph
200 mph ain't crap, I've been 2100 mph but that don't make this scooter top speed claim with stock jets anymore believable. :jack:
