Sym dd50 build!!
Sym dd50 build!!
3 for 21mm
1for 28mm
1for 28mm
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- Trafficjamz
Re: Sym dd50 build!!
The 28 will only give you a couple more mph on the top end, and is harder to tune.
the 21 is easy to tune and uses less gas.
I vote 21mm
I vote 21mm
Sym dd50 build!!
Ok 21mm it is by a win of 4-1
And look what arrived in the post!!
Still waiting for bore kit!!
- ImageUploadedByTapatalk1334545115.798237.jpg (68.15 KiB) Viewed 7426 times
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Just won this one on yahoo auction!!
50mm bbk with gears! now i have a 75cc kit and a 81cc kit which should i use?
- 600x450-2012012400005.jpg (38.39 KiB) Viewed 7407 times
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- paulpauly7
is the brand MTRT if so i have the same kit i bought it cause it was cheap didnt really need it but 8800yen was to good a price to look past the gears were a bonus i got 8.44 to 1 gears with mine
Sym dd50 build!!
Didnt see the brand but I got it for 6250 ¥ plus delivery! And I got it for the gears bbk is a bonus!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- paulpauly7
nice yahoo japan is a great place to spend money .Theres so many parts that they want in usa and they cant get them its kinda a shame really
paulpauly7 wrote:nice yahoo japan is a great place to spend money .Theres so many parts that they want in usa and they cant get them its kinda a shame really
The door swings both ways, I want a trail tech but its a PITA to find something like that over here. The language also restricts me too, my wife helps but then fights with me for spending money on my scooter!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- paulpauly7
go into motorcycles then parts then guages then type trailtech in the search bar the are there i nearly bought 1 but they arnt cheap
Sym dd50 build!!
Yeah I've seen those they are for ninja 250s, I just want a cheap temp gauge I ended up getting a thermocouple.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- paulpauly7
put TTO in the search bar then they are there
Thanks man Ill try that out!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Taida?! Nice, how much USD was it?
And whats the specs on that crank?
Use the 50mm bore, thats supposed to be about 82cc with stock crank.
Sym dd50 build!!
It was something like 42$ plus shipping 27$ it is designed for high performance kits, (or so they said) With a strengthened connecting rod
They have a stock one for 32$ and two stroker cranks for IDK how much.
They sell a bunch of performance parts for DIO engines including a 56mm (I think) water cooled bbk kit including electric pump radiator pipes and connectors! Very interesting!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
did you get the 43.4mm or 44.4mm?
