Christian-
Unfortunately as you found out there is no drain plug on the final reduction box. You have to either remove the cover to drain it (you can spray it all down with brake cleaner and inspect the gears at this time if you're concerned about the condition). You may be able to buy a gasket for it (check cheapcycleparts.com) or you could use RTV to seal it up. I've successfully reused the gasket in the past.
Otherwise, you're either tipping the bike over or pulling the motor to drain it out. It's not the friendliest oil change.
Spree Transmission Oil Change?
fatcharlie
- Goped
Re: Spree Transmission Oil Change?
1986 NB50
indetrucks
- Goped
Thank you sir.fatcharlie wrote:Christian-
I just recently got the scoot and threw in a new top end. Probably wise to get the oil changed out for peace of mind.
I pulled the inspection bolt and there is oil, so that's good
Time to tip the baby over I guess... such a strange way to change the oil. hahaha
-Christian
Too stupid to learn! I'm done with this moron.
indetrucks
- Goped
Good idea to quite while you're ahead Fred.Bear45-70 wrote:Too stupid to learn! I'm done with this moron.
Choose your battles more wisely next time big guy, ya never know who's behind the keyboard you're insulting.
But I will say this, I think we all know who turned out to be the "moron" in this thread.
(You DID teach me how to use Google Images, so thanks!)
Oh well.. it was fun
-Christian
I am having an issue with not having the fill bolt in my Spree and needing to go to hardware store for a replacement. Does anyone know the right size (thread pitch, length?) of this bolt for my 1986 Spree? I am in the process of cleaning out the drivetrain thoroughly and making sure that all the components are in good working order... Thank you in advance =)
1986 Honda Spree Partial Skelly w/ custom exhaust 8500miles
