NQ50 Big Bore Kit Instructions?
Candies
Post by Candies »
Hello all! I just got a 1985 Honda Spree :geekdance:. It runs great so far, however, all the roads I need to travel on are at most 35mph. My Spree, Candies, tops out at 25mph on a flat surface. I've done some research and seen that you can buy a big bore kit from chopchop001 on ebay to make it go at least 35mph. I am mechanically inclined but by no means a mechanical genius or claim to know why things work. So, my question is, how easy was it to install one of these kits, do I have to buy anything in conjunction with this kit to make it sucessful, and does the kit come with instructions? Thanx.
Re: NQ50 Big Bore Kit Instructions?
Post by swimmingfree »
witch kit are you thinking of doing??? chopchop001 i thing is tazland001 on here ..
Candies
Post by Candies »
The 48mm. Thanks, I'll look him or her up.
"Well, this fits here...like that...and this here...like that...and d***, I broke it AGAIN" hahaha
Him and he is outside Vegas.
heres 2 and i think he has 3 kits all 48 mm and the one i cant fine has a bigger carb then stock...
http://www.ebay.com/itm/Honda-Spree-Eli ... 3374dbe3ab
http://www.ebay.com/itm/Honda-Spree-Eli ... 564627f90d
Candies
Post by Candies »
Thanx again...will the 48 get me up to 35mph?
this one yes the other it shood
Candies
Post by Candies »
Im not seeing a difference in these kits... :newb:
The Stage 2 kit is a 48mm BBK with a 16*82 gear ratio upgrade. The gear ratio is what provides more top.
*This gear set will work for the elite E (SB50) but you will have to shave the secondary gear for it to fit into the bearing. This work is only required for the Elite E(SB50) and not for the spree. Your local machine shop can provide this service.
Here is his store. Get the kit with the gears or your top speed will have minimal change.
http://stores.ebay.com/alluneed-scooter ... 4340.l2563
FYI, I think he is out of carb/intake kits right now.
Oh and the difference in the kits is that the stage 2 has the gears, which is what you want.
Candies
Post by Candies »
You know, maybe I'm jumping in too fast..Imma check for carbon buildup and loose belt to see if its just a performance issue. I think the 85 should be able to get up to 35 by itself no problem...:wink:
onna spree
Post by onna spree »
Nope! :sad:
wish you luck on it ... if your lucky you will get 30 but it done hurt to try... you may want to try this as well http://hondaspree.net/wiki/index.php5?t ... r_Cleaning
swimmingfree...
I have the Tazz kit and re-did an old pipe
My little spree is a blast to ride
and the extra power is noticeable but don't think you will be popping wheelies .
Well small ones maybe ?
Candies
Post by Candies »
Hahaha no wheelies for me. Im just trying to get where I need to go and go the speed limit. If you guys dont think I can get at least 30 without a kit I believe you, I am inexperienced here. I just dont want to buy the kit and it turns out to be a complete custom job nightmare.
