INTERMITENLY WORKING TURN SIGNALS ON SB50P
larryhobman
I SUSPECT I HAVE A BAD RELAY. IS THERE ANY WAY TO REPAIR THE ONE THAT I HAVE, I SEE IT IS CONNECTED TO THE SPEDO IN THE BOOK.
- Dio89Elite
Re: INTERMITENLY WORKING TURN SIGNALS ON SB50P
It could be that, but be sure to check on other things as well.
Check the wiring from end to end, there may be a fray somewhere causing a short every now and then.
My first thought is to check the battery connections, a loose ground would cause intermittent problems too.
Good luck! and let us know what you find.
Unsure of repairing the unit, perhaps some the others with more technical expertise will be able to help...
When doesn't it work?
Mine used to stop working when I applied the brakes. The battery didn't have enough juice to support the signals and brake light when the engine slowed down. I got a new battery and that fixed my problem.
larryhobman
Thanks all for the responses. I cleaned the relay contacts and put in a new battery and it works good now.
- paulpauly7
did it take a year and a half to clean the contacts ?
...and put a battery in it, cmon...
He for sure could have put a dio in it in that time
I give him credit for following up on a repair thread, most just disappear like a fart in the wind
84 Aero125 Goldie, For Sale, parts bikes too
09 Stella For Sale
86 Razz
87 YSR50
56 LD150
79 P200
09 Stella For Sale
86 Razz
87 YSR50
56 LD150
79 P200
