Sym dd50 build!!
Sym dd50 build!!
Got the standard 41.4 mm didn't want to mess around with compression on my first real build!
But I'm gonna buy another DIO engine off yahoo and build a stroker after this!!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- paulpauly7
Re: Sym dd50 build!!
keep your eye on those dio engine auctions about 3 weeks ago i bought 4 af18e engines all complete with carbs,airboxs,looms and rear wheels one of them has some sort of aftermarket carb on it all for 30000yen i havent got them yet dont know what im gonna do with them yet either
- paulpauly7
I love yahoo auctions
if you build a stroker, go big or go home.
use a af16 cuz the crank case is made of better stronger material
- Downsouthdio
Tabs ,, u know a shop out there called FRI.. Full race imports?
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Yea i buy some parts from the shop down here, westside.
My friends run the shop here while the owner runs his other shop down town side
Why?
Why?
- Downsouthdio
Just Wondering.. Thats where i get my parts from..
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
- Downsouthdio
Sym dd50 build!!
I think I may have been screwed on the 50 mm kit what do you guys think
Check these photos!
This is the condition it was delivered in!!
I don't think it's 50mm either
Check these photos!
- ImageUploadedByTapatalk1335364124.108160.jpg (61.7 KiB) Viewed 7402 times
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
I think that is a minarelli base gasket
- Downsouthdio
Sym dd50 build!!
How many mm should a 81cc kit be? The brace gasket does not fit!! The head is scratched and dented the top gasket is un useable too, the gears look ok but they are probably for a lawn mower the rate this is going lol!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- Downsouthdio
Lol..i think 50mm.. Jus do a custom base gasket.. Top gasket any
70cc minarelli head gasket will work
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
I would email the people you got it from and find out what the deal is, maybe they can refund you some money or send you another kit. You may have to get some fine grit sandpaper to smooth out the rough spots on the gasket surface of the head etc I would definately complain
