Sym dd50 build!!
Re: Sym dd50 build!!
can confirm that the gears are 15, 42
And on another note I emailed the seller of this kit and asked him to supply new gaskets "that fit" and replace the 48mm bore with the 50mm bore which was advertised!!
This was the link Where i baught it he is still selling the kit!
http://page22.auctions.yahoo.co.jp/jp/a ... l136171987
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- Downsouthdio
48mm pistion got seize? going to 50mm ,need 50 mm head , gaskets.also
Sym dd50 build!!
I paid 7800¥ delivered!!Downsouthdio wrote:What was the price on that kit?
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
He got back to me this morning he is going to replace it with the correct kit and parts! Or so he said in his email!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
they should have measure before send out ..
Sym dd50 build!!
veedubh20 wrote:they should have measure before send out ..
I bought it on my wife's yahoo account, think they thought it would be easy to scam a woman!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
Ok so I started disassembly!
That's so far!!
That's so far!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- Downsouthdio
Sym dd50 build!!
Ok making progress!!
See the pitiful boost port!!
how the * do I get the bering out of the case?
And how the * do remove the crank from the other side of the case?
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
Kn kikaku vs yahoo who knows Bbk
Kn kikaku on the left!
Both 48mm kits !!
Both 48mm kits !!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
My biggest concern at the moment is how to get the Bering out of the case and how to get the crank out of the case. I've smacked it with a rubber mallet and it would not budge( don't care if I break the crank as I'm replacing it but don't want to damage the case. See photos
- ImageUploadedByTapatalk1335543825.597248.jpg (71.67 KiB) Viewed 6946 times
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
And the crank.
- ImageUploadedByTapatalk1335543980.459449.jpg (69.97 KiB) Viewed 6945 times
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Well, the obvious answer is to get it pressed out for 5 bucks somewhere.
OR
http://www.rockymountainatvmc.com/p/44/ ... -Separator
OR
2000 Elite: oko 24 (45/135), corsa, pg short, keli vari, 8.44 secondaries = 71mph gps
1995 Jog
2004 Malaguti F15
2007 Ducati Monster S4r
1995 Jog
2004 Malaguti F15
Sym dd50 build!!
Thanks I'll either take it someplace and get it done of make something like that to do it I guess but it won't help with the stuck bearing!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
