93 elite sr50 simple ways to gain some power
rag
Post by rag »
I have a 93 elite sr50 and wondering on how to increase some speed out of it, currently it runs around 38 top speed but looking for more speed, have excellent low end take off just seems maybe it needs higher geared for more top end, any suggestions would help. Don't think its restricted as serial number is a af1603pd if that means anything
paulpauly7
Re: 93 elite sr50 simple ways to gain some power
Post by paulpauly7 »
aftermarket variator and or a wider belt is the easyest way to catch a few more mph
rag
Post by rag »
okay and any certain brand variator?
allisswell
Post by allisswell »
kelley daywot on ebay
Post by eliteguy50 »
allisswell wrote:kelley daywot on ebay
Keli
Actually you can save a few bucks and put up a WTB ad for a used Ruckus variator. Here or on Total Ruckus forum. Conflicting accounts on whether it fits your SE/05 block straight up, but if not there's just a little shaving to be done around the starter housing webs. The larger diameter of the front pulley translates into a couple extra MPH if you have the power to exploit the taller "gearing". Also, a 90/90 rear tire increases your distance-per-tire-rotation for another fractional gain in top speed.
Ultimately though, taller "gearing" won't necessarily make you faster unless you have more power or better aerodynamics. Preferably both. This is why Experienced Forum Members always ride downwind. Some of us wearing Danskins. :shock:
OneBulletDan
Post by OneBulletDan »
Now, there`s a vision I`d just as soon not have running wild in my head.......
Single-Shot Sez:
Donning the Lycra for speed? All in the interest of Science, of course.
But y'know, anybody Boast-posting a Top Speed number probably wasn't running upwind against a gale, right? Bonneville requires a 2-way average for the same reason. It ain't Official until you average the upwind/downwind runs on the Salt.
paulpauly7
i top at 55mph with the wind and 49mph against the wind
oh its a se50 with a variated afo5e extreme ported case with a ported malossi bore with 10:1gears and 3.00 rear tyre soon to have a dio gear swap with 9:1 gears ill see how that goes then ill try the 8:44 to 1s
JJ Joseph
Post by JJ Joseph »
Wheelman-111 wrote:This is why Experienced Forum Members always ride downwind. Some of us wearing Danskins. :shock:
Crouched down with only our eyeballs showing above the headlight :lol:
Downsouthdio
Post by Downsouthdio »
:bowrofl:
Honda super dio
Corsa
26mm
Sparrow
