Madman
Posts: 261 Joined: Sat Sep 24, 2011 8:25 pm
Post
by Madman » Sat Apr 28, 2012 6:56 pm
paulpauly7 wrote: yip looking good
that is the kit ive got are you gonna try it out or use your other kit you have
Yeah I'm going to use it!! The ports on this one are really smooth and it's in really good condition better than the kn kikaku one that paid three times as much for!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
veedubh20
Posts: 1667 Joined: Sat Dec 31, 2005 7:00 pm
Post
by veedubh20 » Sat Apr 28, 2012 10:50 pm
the pilot jetting and main jet start off 52-150 . then work out down size jet.. 32:1 premix.
because the boost port you made it bigger.
Madman
Post
by Madman » Sun Apr 29, 2012 9:23 am
veedubh20 wrote: the pilot jetting and main jet start off 52-150 . then work out down size jet.. 32:1 premix.
Cheers man I was about to start asking about that!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post
by Madman » Sun Apr 29, 2012 12:47 pm
Got the whole engine reassembled today I'm tired and it's late, done about 30 hours work into this build so far!!
Any tips for break in?
Probably get it back in the bike tomorrow.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post
by Madman » Sun Apr 29, 2012 11:02 pm
Got the bike back together today, will go and get a new spark plug and jets later then I'll try to start it!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
paulpauly7
Posts: 1684 Joined: Tue Feb 21, 2012 6:57 pm
Post
by paulpauly7 » Mon Apr 30, 2012 5:36 am
Madman
Post
by Madman » Mon Apr 30, 2012 6:10 am
Time to jet!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post
by Madman » Mon Apr 30, 2012 6:12 am
Got her running today!! Did 2 heat cycles sounds really different! Very crisp and responsive!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post
by Madman » Wed May 02, 2012 6:58 am
Went for a short ride with a 28mm carb but will be swapping back in my 21mm carb tonight. It's raining and bad weather today and maybe tomorrow but I will see if I can get it dialed in!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post
by Madman » Mon May 07, 2012 12:05 pm
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
veedubh20
Post
by veedubh20 » Mon May 07, 2012 12:51 pm
it is the 21mm carb that you ran 50mm?
Madman
Post
by Madman » Mon May 07, 2012 1:01 pm
veedubh20 wrote: it is the 21mm carb that you ran 50mm?
No I changed to a 28mm and used a 55/145 jet.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
fastplastic
Posts: 1085 Joined: Tue May 11, 2010 7:37 pm
Post
by fastplastic » Mon May 07, 2012 1:20 pm
that jetting is rich for the 82... air leak for sure with new gaskets on the bore and intake i would check crank seals, did you reuse them or new and what about air pump plug or gear ground off? and is the rubber boot on the crab good and tight?
Madman
Post
by Madman » Mon May 07, 2012 1:36 pm
I did new crank seals boot on carb is tight. Ct intake is my expectation! Oil pump was plugged correctly !
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Downsouthdio
Posts: 835 Joined: Wed Dec 21, 2011 11:00 am
Post
by Downsouthdio » Mon May 07, 2012 9:17 pm
how much break in time did u even have before getting on it..mixture is wrong sumwhere bigtime..you should have had some sort of sign to let you know before that would happen man..take it easy on the motor for a little and gradually work on giving it throttle..plug chop after wot pulls after its broken in a little at least..good luck..
Honda super dio
Corsa
26mm
Sparrow
