Sym dd50 build!!
Madman
Sym dd50 build!!
Post by Madman »
paulpauly7 wrote:yip looking good
that is the kit ive got are you gonna try it out or use your other kit you have
Yeah I'm going to use it!! The ports on this one are really smooth and it's in really good condition better than the kn kikaku one that paid three times as much for!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
veedubh20
Re: Sym dd50 build!!
Post by veedubh20 »
the pilot jetting and main jet start off 52-150 . then work out down size jet.. 32:1 premix.
because the boost port you made it bigger.
Madman
Sym dd50 build!!
Post by Madman »
veedubh20 wrote:the pilot jetting and main jet start off 52-150 . then work out down size jet.. 32:1 premix.
Cheers man I was about to start asking about that!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Sym dd50 build!!
Post by Madman »
Got the whole engine reassembled today I'm tired and it's late, done about 30 hours work into this build so far!!
Any tips for break in?
Probably get it back in the bike tomorrow.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Sym dd50 build!!
Post by Madman »
Got the bike back together today, will go and get a new spark plug and jets later then I'll try to start it!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
paulpauly7
Post by paulpauly7 »
:bowrofl: :bowrofl: nice very nice :bowrofl: :bowrofl: that new fan looks real good :peace:
Madman
Sym dd50 build!!
Post by Madman »
Time to jet!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Sym dd50 build!!
Post by Madman »
Got her running today!! Did 2 heat cycles sounds really different! Very crisp and responsive!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Sym dd50 build!!
Post by Madman »
Went for a short ride with a 28mm carb but will be swapping back in my 21mm carb tonight. It's raining and bad weather today and maybe tomorrow but I will see if I can get it dialed in!!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Sym dd50 build!!
Post by Madman »
BOOM BOOM SHAKE SHAKE THE ROOM!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
veedubh20
Post by veedubh20 »
it is the 21mm carb that you ran 50mm?
Madman
Post by Madman »
veedubh20 wrote:it is the 21mm carb that you ran 50mm?
No I changed to a 28mm and used a 55/145 jet.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
fastplastic
Post by fastplastic »
that jetting is rich for the 82... air leak for sure with new gaskets on the bore and intake i would check crank seals, did you reuse them or new and what about air pump plug or gear ground off? and is the rubber boot on the crab good and tight?
Madman
Sym dd50 build!!
Post by Madman »
I did new crank seals boot on carb is tight. Ct intake is my expectation! Oil pump was plugged correctly !
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Downsouthdio
Post by Downsouthdio »
how much break in time did u even have before getting on it..mixture is wrong sumwhere bigtime..you should have had some sort of sign to let you know before that would happen man..take it easy on the motor for a little and gradually work on giving it throttle..plug chop after wot pulls after its broken in a little at least..good luck.. :thumbwink:
Honda super dio
Corsa
26mm
Sparrow
