valve stem
cdg1984
valve stem
Post by cdg1984 »
Is there some kind of adapter for our scooter wheels valve stems. I tried to air up the tires with a gas station air pump, and it wouldnt fit. Then I tried a home bicycle pump, and it wouldnt fit either. The problem is that the head of the pump wont fit between the valve stem and spoke part of the rim. Make sense?
Re: valve stem
You need 90┬░ valve stems that stick out to the side. All the tubes I get are requested this way and on my tubeless tires I have the 90┬░ stems.
cdg1984
Re: valve stem
Post by cdg1984 »
Yeah, but I dont really want to buy new tubes if I dont have to. I can probably just find a smaller air pump...I hope
Re: valve stem
Post by eliteguy50 »
What air chuck are you using?
japennell
Re: valve stem
Post by japennell »
Would this work for you?
http://www.harborfreight.com/dual-chuck ... 68264.html
or
http://www.amazon.com/Pacific-Dualies-1 ... roduct_top
I used something like the ones from amazon when I had my spree.
2 stem.jpg (1.23 KiB) Viewed 5871 times
3 stem.jpg (1.9 KiB) Viewed 5871 times
Re: valve stem
That valve stem is for a tubeless rim. Sometimes those air chucks hit the him before you can get the correct seal on the valve stem, check the angle.
geezer101
Re: valve stem
Post by geezer101 »
I had a similar problem with tubes on my elite when I replaced them both. The 90 degree valve stems are challenging to fit, then I also discovered another pitfall - if the tubes are fitted with the valve stems facing the left side of the bike, the rear tube stem is near impossible to access (on my elite anyway). Guess when I found out... :eyeroll: If you're replacing tubes with 90 degree stems, make sure they're both facing the right side of your scoot
