Jetting down procedure?
Madman
Post by Madman »
Ok getting close, got 55/138 and it's running smooth!! Just some more tweaking and I'll be sweet
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
evilone
Re: Jetting down procedure?
Post by evilone »
55/138 on a 21 oko is high. I ran that in a 28 oko on my 72cc setup.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Madman
Post by Madman »
Yeah I should mention I've changed to a 28mm
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Madman
Post by Madman »
So it happened SOFT SEIZE in pilot jet guess I gotta do a leek down test! And I need a CHT badly.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
bakaracer
Post by bakaracer »
what are you mixing at? do you have a 55 pilot?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Madman
Post by Madman »
32:1 premix! Yes have 55 pilot!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
paulpauly7
Post by paulpauly7 »
check for airleaks around the cylinder,intake and case seals
evilone
Post by evilone »
Madman wrote:So it happened SOFT SEIZE in pilot jet guess I gotta do a leek down test! And I need a CHT badly.
Same here. I've tried a 55 and 58 pilot with a 140 main and am soft seizing too.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Madman
Post by Madman »
It's a real bummer and I hope I haven't destroyed my bore! Still runs ok but I'm too scared to ride it until I get a cht and tear it down to search for a leak, if I have one!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Mystic
Post by Mystic »
If and when you do take it apart you can smooth out the piston skirts with a wire brush on a bench grinder if the scoring isnt too deep it should work just fine :D some of these taiwan kits need the piston skirts chamfered so they dont scrap the oil off the cylinder walls and the ports chamfered so the rings dont catch
Madman
Post by Madman »
Mystic wrote:If and when you do take it apart you can smooth out the piston skirts with a wire brush on a bench grinder if the scoring isnt too deep it should work just fine :D some of these taiwan kits need the piston skirts chamfered so they dont scrap the oil off the cylinder walls and the ports chamfered so the rings dont catch
check the damage on my other post Madman goes KABOOM
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
If you want to do it wrong, then this will work, maybe but it is not the correct way to go, EVER!
Mystic
Post by Mystic »
If you want to hone the cylinder and get a new piston and rings then go for it but since you have the other brand new kit why not squeeze every bit out of the damaged one since you are going to junk it anyway right?? honing the cylinder and buffing the piston smooth where it seized will work :D
Madman
Post by Madman »
Mystic wrote:If you want to hone the cylinder and get a new piston and rings then go for it but since you have the other brand new kit why not squeeze every bit out of the damaged one since you are going to junk it anyway right?? honing the cylinder and buffing the piston smooth where it seized will work :D
yes interesting idea the bike was still running when I pulled it apart and was not correctly tuned so it would give me chance to tune it more before I go and destroy another kit!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Mystic
Post by Mystic »
It cant hurt :D if you have a bench grinder it will be really easy. put one of those wire brushes on it and brush the piston skirts where it seized, not up and down but side to side then a light hone on the cylinder to get rid of any aluminum that stuck to it. also it wouldnt hurt to make sure that any edges are chamfered on the piston and the ports with a small file. The worst that can happen is you sieze the bore again. I have done this before so i know it will work. Just for giggles I took the stock bore and piston that came with my af16 when i got it that only had like 60 compression and would not start at all. Did what I described and replaced one of the broken rings and it cranked right up
