50mm taiwan bore info
evilone
Post by evilone »
I'm posting this due to madman and i both having similar problems (soft-seize) with similar builds.
Took my cylinder off which i was told had less than 200 miles IIRC.
1. Ring gap is .01"-.02" when it should be closer to .10"
2. piston to cylinder clearance was .002" (not too bad).
3. there are signs of excessive blow-by on the piston so i need to hone to make sure cylinder is round.
4. some of the ports had very little chamfer and exhaust port has zero chamfer.
So...i'm honing the cylinder, putting chamfer on ports, and fixing ring gap. Also going to bevel the piston skirt.
I'll post results later.
Just a F.Y.I for anyone planning on running a 50mm Taiwan bore. And to backup what bakaracer has stated :wink:.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Red Eft Performance
Re: 50mm taiwan bore info
Post by Red Eft Performance »
Good info these are some basics that are never talked about on these forums.
In the 2 stroke world in general a lot of bores dont come with the ports chamfered. This should be done by the installer. In our world The only bore I know of that comes with the ports chamfered from the factory is the Malossi MHR.(If there are others feel free to correct me)
So all the rest should be chamfered.
http://www.youtube.com/watch?v=bFkpxW4x ... xt=1&list=
Red Eft Performance
View products click => Here
Madman
Post by Madman »
The ring gap on mine is way too small just visually it's too small, I should have not assumed that it was correct even though I bought it as a kit, piston clearance is also questionable but the ports had been beveled ! But I must have a air leak someplace to "soft seize" like I did!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
bakaracer
Post by bakaracer »
ring end gap should around .010-.014 . Up to .018 is limit. The reason why I say run a hone through a new taiwan bore is because a lot of then the bore is not round and has some high spots. Plus a lot if not all don't come chamfered in the ports. The piston bottoms are not beveled either.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Majourlittle
Post by Majourlittle »
As confirmed by Darin, The Tiawan bores lack a considerable ammount of QC. In fact the piston that I had in my Tiwaneese bore was much bigger at the skirt than at the dome. I believe that if I had run the bore withought checking this beforehand, I wold have soft seized under normal running conditions.
bonesv
Post by bonesv »
Majourlittle wrote:As confirmed by Darin, The Tiawan bores lack a considerable ammount of QC. In fact the piston that I had in my Tiwaneese bore was much bigger at the skirt than at the dome. I believe that if I had run the bore withought checking this beforehand, I wold have soft seized under normal running conditions.
Just curious as to how you remedied that piston issue?
And was there anything else you did to the cylinder other than the above suggestions?
Thank you for the help. :)
bonesv
Post by bonesv »
evilone wrote: 2. piston to cylinder clearance was .02" (not too bad).
Evilone, you mean .002 two thousandths. :wink:
evilone
Post by evilone »
Yes .002, 2 thousandths. Edited.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Red Eft Performance
pistons are larger at the skirt than the dome. When measuring a piston you always measure it just up a little bit from the bottom of the skirt 90 degrees out from the pin. You measure in this location cause typically it going to be the largest point.
Red Eft Performance
Madman
Post by Madman »
How about this?
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Mystic
Post by Mystic »
wow that is definately not true round, possible reason for seizure??
damnSA50
Post by damnSA50 »
is that the piston ring?
Madman
Post by Madman »
damnSA50 wrote:is that the piston ring?
yes it's the piston ring. The gap is the main point! The cylinder is round it just looks distorted in the photo!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Fishman43
Post by Fishman43 »
Madman wrote:yes it's the piston ring. The gap is the main point!
Do you have a set of feeler gauges to check the gap? It is really hard to get a sense of the small differences (tens to hundredths) by eye.
bakaracer
Post by bakaracer »
You have to check with a feeler gauge to make sure what the gap is at. But just by looking from your pic ,that looks like its more than enough. My guess is .013
91 yamaha tzr 250r
