mlangdon521@hotmail.com
Posts: 1 Joined: Tue May 09, 2006 12:45 am
Post
by mlangdon521@hotmail.com » Tue May 09, 2006 12:51 am
how tight should the drive belt be on the 87 spree? also, is there a tensioner or some way to tighten a lose belt?
darat
Posts: 3132 Joined: Fri Jul 23, 2004 10:24 am
Post
by darat » Tue May 09, 2006 7:05 am
wait y is ur name like 5k words long its a nick name not a email address
tonrogs
Posts: 51 Joined: Mon Jul 23, 1973 10:24 am
Post
by tonrogs » Tue May 09, 2006 7:44 am
It will tension itself. That back pulley should pull it tight. The back pulley has a spring that pushes the two pulley halves together and forces the pulley outward, this is what auto-tensions your belt. If your belt is loose, then you most likely need a new belt. Double check that your rear pulley is operating properly though too.
MySpree
Posts: 3291 Joined: Mon Jul 23, 1973 10:24 am
Post
by MySpree » Tue May 09, 2006 8:32 am
i have extra belsts
mopedman
Posts: 1213 Joined: Mon Jul 23, 1973 10:24 am
Post
by mopedman » Tue May 09, 2006 9:10 am
you probly need a new belt, i have one
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
