drive belt - 87 spree
mlangdon521@hotmail.com
Post by mlangdon521@hotmail.com »
how tight should the drive belt be on the 87 spree? also, is there a tensioner or some way to tighten a lose belt?
darat
Post by darat »
wait y is ur name like 5k words long its a nick name not a email address
tonrogs
Post by tonrogs »
It will tension itself. That back pulley should pull it tight. The back pulley has a spring that pushes the two pulley halves together and forces the pulley outward, this is what auto-tensions your belt. If your belt is loose, then you most likely need a new belt. Double check that your rear pulley is operating properly though too.
MySpree
Post by MySpree »
i have extra belsts
mopedman
Post by mopedman »
you probly need a new belt, i have one
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
