High performance rollers
Re: High performance rollers
Post by swimmingfree »
im running 4 grams but to say its the one to make i wood guess 6 or 8 wood be my guess..
veedubh20
Post by veedubh20 »
daytona gram are the best roller to use and last longer..
deuce217
Post by deuce217 »
Okay back onto these rollers. I am going to do some testing and see how these work. What weight are the daytona rollers?
Here are a few pics. I will try to get some in production once they prove worthy. I will be sending some beta sets to a few lucky folks once I do.
:thumbwink:
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
deuce217
Post by deuce217 »
50mm BBK (tai)
V-8 pipe
Fishman43
Post by Fishman43 »
Lookin awesome, I hope I am still on the list :smile:
With all your metal shop tools and skillz, it should be reasonable to setup that joe dirt disk brake you are working on.
deuce217
Post by deuce217 »
Dio89Elite wrote:*raises hand* I have a daily driver that can be used for... uh... ahem... test purposes! :thumbwink:
Seriously though, I'd like to get some of your rollers please. Let me know of the cost.
Have you thought of making something like the Polini rollers?
What of trying to replace the rubber/plastic part that covers the metal part with this material?
In this way, you'd just need is to do the rubber/plastic part and just replace that instead of the whole thing?
Would this lower your cost? Or would it be harder to cast? I have no idea and you would know better than I.
Just giving you some food for thought. It might be easier and economically viable to do it the way that you are doing it already.
[img]http://www.racingplanetusa.com/images/g ... t_16mm.jpg?
language=en&shop_ID=1[/img]
That's great idea..
well so far I have out about 80 miles on my new rollers.. There is no visible wear yet, and I don't expect any soon. My current load weight is 40.9 grams It seems to be pretty good for acceleration. Top speed is about 58mph so far what weight do you guys use?
50mm BBK (tai)
V-8 pipe
my drag bike uses a combo of 6's and 7's
Fishman43
Post by Fishman43 »
Trafficjamz wrote:my drag bike uses a combo of 6's and 7's
So then would a set of 6.5's work the same for you, or is the combo of 6's and 7's needed?
deuce217
Post by deuce217 »
How much do you weigh traffic?
50mm BBK (tai)
V-8 pipe
6.5 would be perfect.
I weight 225lbs
those 6's and 7's are used with a 2k center and 125cc stroker, and scorpian pipe.
deuce217
Post by deuce217 »
I weight 225lbs
Do you think I would want to have slightly less weight in my superman motor I got from you since I weight around 190?
P.s. I bought a bunch of material to start pumping these rollers out yesterday!
50mm BBK (tai)
V-8 pipe
The roller weights and center springs work together.
Lighter spring = lighter weights
are you racing or daily driving?
deuce217 have you figer out what thay will cost per set of rollers ???
deuce217
Post by deuce217 »
Daily driving, no drags around here yet. If I set it up for racing would it not be fun around town?
50mm BBK (tai)
V-8 pipe
