won't stay running
spree86
won't stay running
Post by spree86 »
i have a 86 spree and it will not stay running unless i have full throtle i have cleaned the carb and put all new gaskets in it the carb is also leaking out of the down spout in the back can not figure it out any help would be great and thanks
stankyoleman
Post by stankyoleman »
adjust your idle and air mixture screws per instructions, thats most probably the problemo
mopedman
Post by mopedman »
is it all ajusted right
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Farfignugin
Post by Farfignugin »
leaking out of a tube coming from carb? that is carb bowl drain, there is a screw at bottom of carb, should be tightened all the way snug
Your idle jet's plugged. Reclean!
spree86
Post by spree86 »
i had this carb soaking in parts cleaner tank for a week then took a air comp to it everything is allowing air thru it and for the bowl drain tube the screw is in all the way
mopedman
Post by mopedman »
if it ant ajusted right it could be geting tooo much gas and draning out the bottom
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
hondaspree86er
no run
Post by hondaspree86er »
try a new spark plug thats what happend to mine and it runs great now
eman916
Post by eman916 »
Try adjusting the needle. I had a similar problem and I moved the needle down 1 notch (running a little richer) and I readjusted the throttle stop and fuel screws and it fixed my problem.
-=_EmaN_=-
hondaspree86er
ok there might be a hose on the back for your carb that goes to theupper half of the bowl take it off if there is one and see what happens my friends had one and wouldnt run unless it was full throtle then when it started it would die
myhonda
Post by myhonda »
if it wont idle i got 3 words ...... idle ajustment screw.
