won't stay running
won't stay running
i have a 86 spree and it will not stay running unless i have full throtle i have cleaned the carb and put all new gaskets in it the carb is also leaking out of the down spout in the back can not figure it out any help would be great and thanks
stankyoleman
- Farfignugin
Your idle jet's plugged. Reclean!
- hondaspree86er
- BMX
no run
try a new spark plug thats what happend to mine and it runs great now
- hondaspree86er
- BMX
ok there might be a hose on the back for your carb that goes to theupper half of the bowl take it off if there is one and see what happens my friends had one and wouldnt run unless it was full throtle then when it started it would die
