Gyro - general thread
Re: Gyro - general thread
gyromaniac wrote:the only thing i am worried about, is that if i do stretch the rear part of the suspension unit, is that i will need a bigger shock. is it possible to get an aftermarket shock or do you think the original will work?
Gyro is not a very good candidate for trying to look like a "gangstuh"
Leave it alone and enjoy the perfect stance it already has, or get yourself a ruck and make it 10 feet long.
wentwest
Post by wentwest »
I just mounted up 2 new tires I got from www.tires-easy.com. They are lawn and garden tires, but they are not cracked and worn out 27 year old Dunlops either. Look them up under lawn and garden, 5.30 by 6 rim. They have 4 choices. I got the tires, delivered, all in for just under $50. My local Walmart doesn't carry this size. Maybe I need to look in the suburbs, but this way was way easier and I didn't have to drive all over and I really like that I didn't have to go into Walmart.
Now to get the cylinder bored out to 44mm, and get a piston. Tazland told me he's out of pistons right now. Anyone got another source? Otherwise I guess I'll wait.
OK I guess I am still on the re-do Gyro front end .
Well I bought 2 front ends today but they came with an ATV rear end and a Express rear end .
The big problem is every time I get a bike it always runs or almost wants to ...
Why can't I find a Honda with a seized engine or better yet no engine ?
Life would be so much easier .
Now I am starting to price a set of tires for the ATV .$$$
Yes a little starting fluid and waa waaaaa weaaaaaaa runs strong as does the express .
What to do ? What to do ???
Anyway here are some mock-ups on photoshop ...
Think of the steering ? It would be so messed up ...Gotta try it ....
This would be insane .But I could bump into the back of cars for fun .
atc front rim .jpg (65.43 KiB) Viewed 6518 times
OK then there is an Express front end as well everything looks like it will match as all of the forks are a little over 7 inches where they attach to the frame I really think this could work .....
Pretty trashed  but .... Runs  what to do ?
Beat to $hit
Beat to $hit
Why not ?
Why not ?
express wheel.jpg (68.57 KiB) Viewed 6517 times
OK i was messing around and was thinking I do have an extra Gyro frame .
If I did this would it still be a Gyro or and ATG. ?
But still with almost a 200cc engine hmmmmmmmmmm ?
And yes the engine would sit a lot farther back so the front would still tilt ...
express wheel copy.jpg (89.25 KiB) Viewed 6515 times
I still think I can mount a express spoked wheel on a gyro ...
so here goes ...
I tried  the gyro forks on the express ...it fits
I predict some under-steer...just sayin'...but you gotta go for it 66SIX.... :rock:
tazland001
Post by tazland001 »
your a riot six. d*** those are some funny pics. :lol:
taz
Sure are, keep building!
gyromaniac
Post by gyromaniac »
If anyone wanted a set of decals but missed out, heres your chance to still get some! I have only two sets left and then thats it for a while.
EBAY LINK: put color of decals in the buyer comments
http://www.ebay.com/itm/Honda-Gyro-Deca ... 500wt_1287
tazland001 wrote:your a riot six. d*** those are some funny pics. :lol:
taz
GO AHEAD LAUGH
OK I will Almost Done ...
So tell us 66SIX,...is this a direct bolt-on :?:
What is the distance from pavement to footpeg for both the stock bike and the modified bike :?:
How does the steering differ :?:
Do you feel way cooler now :?:
What are you using for headlight :?:
Will you sell me the PA 50 :?:
Will you bring it to me :?:
I love you, man :mrgreen:
[quote="motormike"]So tell us 66SIX,...is this a direct bolt-on :?:
:surprise: Yes almost a direct bolt on / you need to cut and grind the back of the forks
the lock holes don't line up . no biggie ...
:surprise: Distance from pavement to foot peg spoke wheel is 10'
Gyro front end is 9' so your only talking an inch ...
:surprise: Steering I tried to take it for a test run got 5 " then it died
:surprise: Much so
I chopped a front gyro fork long ago I was going to put different headlight on one
so I still have the old mount and signal mounts so some plate steel and some welds
it will be great... as I will make the plate bigger so I can add toggle switches later or I phone
and cig lighter or drink holder or fuzzy dice .
:surprise: It's too much fun ... was riding it today
:surprise: Thats probably not going to happen ...
Here are some things you might want to consider :
You have to use the Express handlebars which are shorter ...
You will have to make mounts for a headlight ...
as for the speedo I am not sure how accurate its going to be ?
the gyro forks look a lot stronger so if the express snaps I will know why .
Also put a sheet or something on the ground to catch the ball bearings when they start falling out after I was all finished I found 1 bearing on the ground ... Oh well ?
spoked wheels should have been an add on from honda .
Oh the brake cables are very different
More pics
