What size jet do i run
smokindon
Post by smokindon »
I have an 88 elite lx sa50 with malossi bore kit
Af05e
Stock carb stock intake stock exhaust
Does anyone have experience with this or a similar setup? I have the kit daywot sells with jets 85 thru 105.
Currently running a 90 main
Sent from my MB855 using Tapatalk 2
1988 Honda Elite LX - AF05E w/ 65cc Malossi MHR, OKO24, CT Manifold, UNI Filter, Ruckus Variator, Custom DIY Briggs & Stratton Exhaust, Met Front & Rear Wheels, 95mm Front Brake Conversion
Re: What size jet do i run
90 is in the ballpark for that setup. Does it seem to run well or not? If you posted this Q, it implies you're not completely satisfiied.
Remember that the stock carb exacts some compromise due to the non-modifiable (or is it?) Pilot circuit. How does it perform at WOT?
(There is the option of drilling your Pilot and/or emulsiom tube...)
To confirm, check the spark plug color after a minute Wide open. Better would be a CHT reading of a steady 375 with no spike with throttle closed.
smokindon
Post by smokindon »
Seems to run well, I haven't driven it at WOT yet I'm still trying to break it in. Need to get some plugs to do chops with. I was just paranoid about running it lean. My friend upjetted his Tomos 8 sizes when adding his exhaust so it made me think going to to a 90 from an 88 with a bore kit could be too lean.
I don't have a CHT gauge which unit would you recommend? I'm looking for a budget piece.
SuprasNsprees
Post by SuprasNsprees »
Trail Tech. Love mine
'80 Puch Magnum MKII
'78 PA50 Hobbit
Mystic
Post by Mystic »
Definately trail tech TTO is the best bang for the buck and will save you many hours of grief in the long run. I dont even want to ride mine now without a temp gauge lol a tachometer doesnt hurt either but not as important until you get down to fine tuning the trans etc
