Ive had so much problems with my 130cc it is unbelievable!
Two weeks straight I tore it apart and put it back together just to find out what was wrong.
Turns out it was the heat wrap on the pipe? Causing loss of power on take off
Its a whole different monster now
SpreeMadness520 wrote:Ive had so much problems with my 130cc it is unbelievable!
friday is the first race event.....
lets show some street cars what fast is all about.
I will rule the 10 sec class
Im interested in your theory on the heat wrap??
I have ran it on many vehicles... cars, bikes, scooters etc with out ever causing a tuning issue.
In fact just put it on the Honda mini dragger for the race this weekend and made some test passes Sunday with no issues.
What do you think its doing to your scooter to make it loose power on take off?
It was not the heat wrap. It ended up being a bent flywheel key.
bakaracer wrote:
believe it or not it increases hp and torque with the 4 reed design.yeah it has 4 reeds on that cage. moto tassianari makes one for stage6 which holds the 1/8mile record on a 70cc setup which is under 8sec.
What is the 1/8th mile record on a 70cc setup?
They dont race the 1/8 mile
One of the fastest times I have heard is from my friend Marc Grauer who help start the maxiscoot magazine. In 2006 did 7.44@78.4 in 150 meters (164,05 yards) on a 70cc set up..
That doesn't look dangerous at all. Head facing the ground, no leathers on.
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
