Re: can someone guide me to the right directions?????
Suup Bear45-70Bear45-70 wrote:The last 2 quarts of GN2 I bought say the same thing. I would not worry about it.
got some questions for you ? Now I have took my SA50p Elite for a ride today .I drove it for 15 miles .It does take of normal .30mph on flat and 35mph down hills . On my way back There is that rattling sound that I am starting to hear . I is not loud but can hear it . Then I parked it on the side of the road. The rattling sound did stop but I am Still able to hear a click sound every 2second inside the engine . Any ideas what is going on. Any one that had experience the same problem feel free to tell me what should I do.
Re: Rattling and clicking sound please help
I still dont know what to do about that vibrating and rattling sound I am getting from my engine .
I got the headlight panels done today and she is looking good. Ill post some better pictures later on .
- IMG_2395 (495x640).jpg (72.22 KiB) Viewed 5625 times
Now I have took the engine apart again because of that vibrating and rattling sound that I am starting to hear. I have know Idea where it is coming from. I don't know if I have to change my belt or what . It is starting to drive so rough after that 15 miles I put on it . When I hit 15mph it feels like when You are rubbing 2rocks against each other.Also it is so loud .It is like driving a sport bike. I check the engine and it look nice and clean to me. So some suggestions will be very helpful. Thanks
- IMG_2404 (640x480).jpg (56.07 KiB) Viewed 5624 times
- IMG_2403 (640x480).jpg (56.41 KiB) Viewed 5624 times
- IMG_2402 (640x480).jpg (61.94 KiB) Viewed 5624 times
Some advice here will be really helpful. After putting 15miles on my elite. It is starting to smoke so bad . Now it sound like an harley. I can feel the engine vibration sitting on .It will run smooth at 5mph. Once I hit 10mph the vibration is so bad that I cant even ride it.Now it does start fine either kick start or electric start. I did a compression test and I get 65psi.So do I need to change my rings and my gasket?
Re: Some advice here will be very helpful
65 PSI and it starts and runs? My 60 PSI Aero 50 doesn't ever pop, not even once.
You need to pull the jug (cylinder) off and see how bad things are.
Rarely will a 65 PSI engine just need rings and gaskets. Usually an overbore, piston & rings or a BBK.
yes it does start and run at 65psi . Once I hit 10mph it smoke so bad and You can hear the engine start making some terrible noise.Like metal rubbing against each other. Now I was on cheapcycleparts.com looking for the parts . I found the gasket ,the rings that I am needed . Now what do I need to buy to seal the new gasket on the cylinder in place ounce I took it out.
What is a BBK?
What is a BBK?
If you lean the bike one way does the 'vibration' stop? Maybe a crank bearing. My elite started doing that so I pulled it off the road. I took it apart and the left bearing was toast - so much so the teeth on the starter wheel had started touching the inside of the case, making a nasty metal to metal sound
. BBK is an acronym for Big Bore Kit, this will contain all the parts to increase your stock engine cc's. Site search engine is your friend
Ok guys I took my cylinder of just now. I really don't know why it will be smoking so bad. Because inside the engine looks so clean like brand new. My pipe got know holes.
Why it will run rough ?
Also will a 1989 SB50P piston rings fit in a 1998 Sa50P Honda elite?
- IMG_0829 (640x480).jpg (74.07 KiB) Viewed 5585 times
- IMG_0827 (640x480).jpg (69.61 KiB) Viewed 5585 times
- IMG_0825 (480x640).jpg (73.06 KiB) Viewed 5585 times
some more pics what it is look like
- IMG_0834 (640x480).jpg (66.31 KiB) Viewed 5583 times
- IMG_0833 (640x480).jpg (63.52 KiB) Viewed 5583 times
more
- IMG_0850 (640x480) (640x480).jpg (71.2 KiB) Viewed 5582 times
- IMG_0839 (640x480).jpg (39.41 KiB) Viewed 5582 times
- IMG_0840 (640x480).jpg (58.65 KiB) Viewed 5582 times
My questions are
WIll a 1989 Honda SB50P piston and rings will fit a 1998 Honda Elite SA50p?
DO I need to change my ring and piston?
Why is it smoking so bad ?
WHy is it running like those tractor with a chains wheels on a hard surface?
- WHy is it running like those tractor with a chains wheels on a hard surface?
- 39c0eb32d27f6b25bab6d170c7ad056c.jpeg (15.54 KiB) Viewed 5582 times
clement235
I'm buying a 1988 Elite SA50-LX next week. Apparently the crank bearings may be bad in it.
I'll keep you informed about what I learn/find. Maybe we can help each other out! Yay!
