Kit came with two gaskets and my mistake it looks like it clears the ports with both gaskets on the base!!
Also deck height is 68mm on this 50mm bore!!
Also at TDC it looks like this with both gaskets!
Looks like .8mm with the feeler gauge.
50mm taiwan bore info
- ImageUploadedByTapatalk1337935891.415217.jpg (67.59 KiB) Viewed 1302 times
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
