Re: Some advice here will be very helpful
sound awesome because right now I have bunch of stuff adding in my cart and don't know if my problem will be succeed .
This is my list
A Piston(don't know if I really need it )
Ring Set (Os) (0.50)(I think I do need it )
12191-GAH-A00
Honda
Gasket, Cylinder ( THink I do need it)
17111-GAH-A00
Honda
Gasket A, In. Pipe ( definitely since I took it of )
17112-GAH-A00
Honda
Gasket B, In. Pipe ( definitely since I took it of)
12251-GW0-000
Honda
Gasket, Cyl Hd ( definitely since I took it of)
23100-GG2-751
Honda
Belt, Drive ( don't know if I need one.)
also what will you used to seal those gasket in place?
This is my list
12191-GAH-A00
Honda
17111-GAH-A00
Honda
17112-GAH-A00
Honda
12251-GW0-000
Honda
23100-GG2-751
Honda
Duke250 wrote:sound awesome because right now I have bunch of stuff adding in my cart and don't know if my problem will be succeed .
This is my list
A Piston(don't know if I really need it ) If the cylinder needs boring, you need a piston.
Ring Set (Os) (0.50)(I think I do need it ) See above.
12191-GAH-A00
Honda
Gasket, Cylinder ( THink I do need it) Always replace gaskets, they are a one time use item, regardless of the guys that don't do it
17111-GAH-A00
Honda
Gasket A, In. Pipe ( definitely since I took it of ) See above.
17112-GAH-A00
Honda
Gasket B, In. Pipe ( definitely since I took it of) See above.
12251-GW0-000
Honda
Gasket, Cyl Hd ( definitely since I took it of) See above.
23100-GG2-751
Honda
Belt, Drive ( don't know if I need one.) You have to measure it to know if it is wore out.
also what will you used to seal those gasket in place? Whatever your choice is.
Thanks allot Bear45-70 maybe that is why my moped wasn't running correctly because I didn't replace my cylinder gasket.I think there was a leak. It start great on battery And one kick it will fire up. It does take off normal . I got 32mhp on it . It runs great but sound loud. will run good ounce hit 30mph but once you let go of the throttle the engine sound higher then when you are running on speed.
how do I measure my driven belt?What tools do I need to buy ?
bear45-70 what do you mean cylinder need boring? it look good to me. Also what is the best way or product to used to seal the gasket.
may be all I need to buy is all the gasket ,the piston rings and a belt .
Thanks .
Thanks .
Duke250 wrote:Thanks allot Bear45-70 maybe that is why my moped wasn't running correctly because I didn't replace my cylinder gasket.I think there was a leak. It start great on battery And one kick it will fire up. It does take off normal . I got 32mhp on it . It runs great but sound loud. will run good ounce hit 30mph but once you let go of the throttle the engine sound higher then when you are running on speed.
how do I measure my driven belt?What tools do I need to buy ? Look in the service manual.
bear45-70 what do you mean cylinder need boring? it look good to me. Are there any scratches you can catch you finger nail on.
Also what is the best way or product to used to seal the gasket. Sealer 1000
may be all I need to buy is all the gasket ,the piston rings and a belt . If you don't KNOW for sure, you are asking for grief if you don't have someone that KNOWS for sure look at it first. And I don't mean you buddy who thinks he knows about engines.
Thanks .
I order all the parts through cheapcycleparts.com . Now I did make sure I put the correct year and the model of my elite. I shouldn't have a problem with wrong parts right?
Re: I Just can't believe it I get that junk working!!
Ok Some of you might have seen me posting that junk moped on there for sale and parts. Today I've starting to take it apart so I can post the parts on Ebay. Then I change my mind and tell myself I have to get you running. I took the engines of complete. What I found are . There was no cylinder Gasket on there , no rings on the piston, and no cylinder head gasket. I replace those missing parts. Used my old carb from my honda elite SA50P. After spenting couple hours putting the engines back together. I put some gas in the tank . Try kick starting and that thing just took off like a "JET" I forget to put it on stand when I was kick starting it .I was so happy . All It need now is a new battery,those panels,new tires and a muffler. My muffler have some big holes and that make it so loud .
NOW I HAVE THREE IN MY GARAGE .I THINK I AM GETTING ADDICTED
Also cheapcycleparts.com is really slow with shipping. I have oder couple parts for my elite SA50P since Friday and I am still haven't receive anything.
- IMG_0020 (640x480).jpg (83.48 KiB) Viewed 5281 times
- IMG_0021 (640x480).jpg (81.66 KiB) Viewed 5281 times
Re: PICK UP 2spree Today after selling the SB50P
I JUST PICK UP 2 HONDA SPREE TODAY FOR $149. THE RED ONE HAVE 2384MILES IN IT AND THE BLACK ONE HAVE 1899 MILES IN IT.
- IMG_0870 (640x480) (640x480).jpg (71.89 KiB) Viewed 5262 times
- IMG_0865 (640x480).jpg (89.92 KiB) Viewed 5262 times
YEP GOT SOME WORK TO DO
- IMG_0862 (640x480).jpg (64.02 KiB) Viewed 5260 times
- IMG_0861 (640x480).jpg (85.28 KiB) Viewed 5261 times
1985 spree now have a kick start. it is actually works like a 1986 spree.
- IMG_0041 (640x480).jpg (71.48 KiB) Viewed 5244 times
Re: How many MM is a Honda SA50PW Af16 elite ? Help!!
I have order the wrong piston because it does not fit . The one I order does says sa50p (os)(0.25) and on the piston there is a black writing say (ahf). Where do I find the size of my piston
Ever hear of the service manual? They exist so this kind of information has a place to be written down.Duke250 wrote:I have order the wrong piston because it does not fit . The one I order does says sa50p (os)(0.25) and on the piston there is a black writing say (ahf). Where do I find the size of my piston
Re: How many MM is a Honda SA50PW Af16 elite piston ? Help!!
I can't find the exact manual for sa50p . The one I saw says sa50 88 to 2001
OS would make it 39.25mm, original being 39mm and the 88-01 manual is the right one it will tell you the difference if any between the 88-93 and the 94-01 sa50
Thanks man really appreciate it . If I read it correctly I need a 38.90 mm piston . What does it mean when it says piston with A mark , B mark and No mark mean ?They all seems to have that 38.90mm . Since the one I have order was 0.25 , so I definitely don't need the 0.50 so it seems like I need to order the one that says Piston( STD). What does STD stand for ?Pease broth
STD means standard which would be 39mm (i guess technically a few tenths of a millimeter smaller to fit the 39mm bore) You generally buy oversized piston and rings when you have had the cylinder honed and bored over like .25 .50 .75. or 1mm It would probably be cheaper just to bore your STD cylinder to whichever oversized piston and rings you want to buy. Not sure about the A and B I think mousewheels answered your question on that. To know for sure why dont you call the Honda place you are ordering from and ask?
