DIO swap into sym?
Madman
DIO swap into sym?
Post by Madman »
Anyone know if you can swap a DIO af18 into a sym dd without major modification?
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
LMH
Re: DIO swap into sym?
Post by LMH »
Is the DD 12 inch wheels or 10?
Madman
DIO swap into sym?
Post by Madman »
3.00 10 42j
I think !
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
veedubh20
Post by veedubh20 »
plug n play...
