sym block build
Freedom_ridahz808
sym block build
Post by Freedom_ridahz808 »
finally done with the block.LMK what you guys think.
dv/dt
Re: sym block build
Post by dv/dt »
Clean! What are those marks on the oil pump plug?
2000 Elite: oko 24 (45/135), corsa, pg short, keli vari, 8.44 secondaries = 71mph gps
1995 Jog
2004 Malaguti F15
2007 Ducati Monster S4r
Freedom_ridahz808
Re: sym block build
its like that
tru72
Re: sym block build
Post by tru72 »
People dimple the oil plug to try to keep it in place. If i was you put/make a bracket to hold it in. Nothing worse than it popping out or starts leaking air.. kaboom!
Aloha
D
Madman
sym block build
Post by Madman »
There was a thread about making a bracket for a oil plug and I followed it! But it cost a few yen!!!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Downsouthdio
Re: sym block build
Post by Downsouthdio »
nice motor dude...is that the corsa? this is how i did my plug
oil plug.jpg (42.2 KiB) Viewed 6818 times
Honda super dio
Corsa
26mm
Sparrow
LMH
Re: sym block build
Post by LMH »
Nice engine, but I agree with them all. Do something about that plug or it will come off when you dont expect it and it will be devastating. Also bring your stock fan around with you as those fans like to explode.
Madman
Re: sym block build
Post by Madman »
LoveMyHonda wrote:Nice engine, but I agree with them all. Do something about that plug or it will come off when you dont expect it and it will be devastating. Also bring your stock fan around with you as those fans like to explode.
That is the stock fan for the sym DD dont worry its tough as nails!
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
LMH
Re: sym block build
Post by LMH »
My Kymco zx50 AF18 has the same fan, I figured it was aftermarket. Im relieved now. I carry around an extra AF16 fan everywhere ha.
tru72
Re: sym block build
Post by tru72 »
Yes any fan that is not a real honda one is pretty weak, but as for using on a 72 i wouldnt worry to much about it.
I blew a few on my 72 before, but on my big strokers, its a pain in the * when they blow, new shrouds automatically!
We also sell tons of koso fans here in hawaii. most people but it cause it kinda has a whistle to it lol. Still the oem fan
seems to be the strongest.
Aloha
D
