Big Bore Kit Jet Size- Gy6 Chinese Dio Looking body
My brother in law bought what looked to be a dio clone. But the Motor is a horizontal gy6 type. Any way he put a 72cc kit on her with a v-8 pipe and a intake w/ 28mm oko. The carb came with a 133 main and 42 idle. I have worked down to a 110 and up to a 58 now. The idle is ok, but the bike still wants less main jet. I run a 130-133 in my af16 with 50mm BBk and do not understand why his would not a similar size. We need to order smaller jets I guess but what sizes do these usually like? I am guessing around a 100 main or so. Thanks for the help.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
Re: Big Bore Kit Jet Size- Gy6 Chinese Dio Looking body
just have to remember, dio, jog, gy6 jetting are no the same carb jetting. on oko carb,pe carb. ,stock carb too... it is the motor was design and made..
veedubh20 wrote:just have to remember, dio, jog, gy6 jetting are no the same... it is the motor was design and made..
Yeah we are seeing that. The 28mm carb is way too big we found out. I told him to get a 21mm in the beginning, he bought 28 and now is ordering a 21.. I got it running with a 19mm pretty good, but its no Af16!
50mm BBK (tai)
V-8 pipe
50mm BBK (tai)
V-8 pipe
- Trafficjamz
did the kit come with a larger head and valves?
Its a 2-stroke kit. I may be wrong about the gy6. Its perhaps the Jog.. Its hard to tell as I am not familiar with anything other than sprees and recently the elite 50 SR. They china scooters all look the same to me, cheap. Especially this one.Trafficjamz wrote:did the kit come with a larger head and valves?
For sure its a horizontal style 2-stroke.
50mm BBK (tai)
V-8 pipe
50mm BBK (tai)
V-8 pipe
- Trafficjamz
that might be a yamaha clone
what brand scooter is it?
Not sure on the brand, nothing I have heard of though. The belt did say yamaha on it. A 90 main jet seems to work pretty good on it with a 19mm carb. The rollers are shorter and narrower than my elites.Trafficjamz wrote:that might be a yamaha clone
50mm BBK (tai)
V-8 pipe
50mm BBK (tai)
V-8 pipe
Do you have a picture? Sounds like a minarelli or morini.
I will try to get some later, it is not at my house. Thanks for the help. He is pretty down, he was hoping this thing would be like my elite, and it feels more like my old spree.eliteguy50 wrote:Do you have a picture? Sounds like a minarelli or morini.
50mm BBK (tai)
V-8 pipe
50mm BBK (tai)
V-8 pipe
50mm BBK (tai)
V-8 pipe
50mm BBK (tai)
V-8 pipe
That is a minarelli engine.
Re: Re: Big Bore Kit Jet Size- Gy6 Chinese Dio Looking body
Hmm. Im gonna tell him to order a new piston kit. I will rehone it and try this again from scratch. He seized this thing like 13 times. I tried to get him to build it at my house somebody need to learn the hard way.graphite9 wrote:Which means it should be running way harder than a af16eliteguy50 wrote:That is a minarelli engine.
Sent from my DROID RAZR using Tapatalk 2
50mm BBK (tai)
V-8 pipe
50mm BBK (tai)
V-8 pipe
