Cheap Rollers
Got parts to sell? Need a part? Post it here! Honda scooters only.
Re: Cheap Rollers
I came this close to pulling the trigger on some Dr. Pulley "wedge" rollers while buying Polinis and Malossis this evening. I couldn't bear to part with a Jackson for rollers, though. Plus what weight will correspond with the 32-gram load of round ones I'm using? If someone has converted and can post from experience, I'd be obliged.
atomicareprise
Re: Cheap Rollers
Post by atomicareprise »
dr. pulley is way expensive...
sometimes we just use 4 rollers on our pulley...
PINOY SCOOTERISTA!!!
Re: Cheap Rollers
When I inquired a while back I was told that each slide should be a gram heavier than the rollers.
atomicareprise
Re: Cheap Rollers
rolllers dictate ur accelaration and the top end of ur scooter...
depending on what purpose ur using...
i don't think spending a high price for a roller is not worth it...
u can get a good result using a taiwanese brand..imo..
veedubh20
Re: Cheap Rollers
Post by veedubh20 »
well, you get what you pay.
daytona rollers last long. than other taiwan brand.
Re: Cheap Rollers
atomicareprise wrote:rolllers dictate ur accelaration and the top end of ur scooter...
Unless you are using too light of rollers, your top end should not be effected.
Videonut
Re: Cheap Rollers
Post by Videonut »
funny i have a 86 spree with 6500 miles on it and have never ever ever had the rollers replaced or needed to. Do you think thats because its a spree and low torque? seems to run great!! had to replace the spark plug the other day but it still hits 30mph no prob...??
Re: Cheap Rollers
Videonut wrote:funny i have a 86 spree with 6500 miles on it and have never ever ever had the rollers replaced or needed to. Do you think thats because its a spree and low torque? seems to run great!! had to replace the spark plug the other day but it still hits 30mph no prob...??
You can't replace the roller in a Spree because it has none and that is why the Spree is slow off the line and slow on the top end. It is all compromise.
Videonut
Re: Cheap Rollers
Post by Videonut »
hahahahhahah oh!! wow here i thought i was this wonderful amazing freek of nature. wow i know all about this little bike but didnt know that it doesnt have rollers. cooool then i have nothing to wory about. thanks Bear.
Ya i kinda like the way the spree runs but i have never rode a aero either (i think i will try to avoid one :))
stucinthe80z
Re: Cheap Rollers
Post by stucinthe80z »
GIJoeBob wrote:Check out these funky rollers-
http://www.monsterscooterparts.com/rollers.html
i think i see a flat spot lol do they work well ?
stucinthe80z
Re: Cheap Rollers
Videonut wrote:hahahahhahah oh!! wow here i thought i was this wonderful amazing freek of nature. wow i know all about this little bike but didnt know that it doesnt have rollers. cooool then i have nothing to wory about. thanks Bear.
nice spree i have one . i still love to ride it but my elite is faster and better take off .but i love to sharpin the kickstand on the pavement
sipaboy
Re: Cheap Rollers
Post by sipaboy »
Which rollers can I use for the Gyro Canopy? Mine won't shift to second gear and might as well change the rollers when I open it up to investigate. Aside from which to use and where to get them, would changing the roller make my Canopy to shift to 2nd?
