OK, so, just got it running for first time. BUT....
the petcock is actin crazy....first it would run at idle then quit (after bowl ran dry i think)
then, it filled engine with fuel......
now i unhook both lines from the petcock and both have fuel running out.
anything i can do? recommendations?
fuel petcock problem
trudeau1111
- BMX
trudeau1111
- BMX
Re: fuel petcock problem
yea, i think the float & needle are working correctly.
do you guys keep stock petcock or put on a manual one?
replacements are inexpensive (made in china), although some do use a manual shut off valve with success. I replaced mine 'cause I'm afraid I'll forget to shut off the manual one.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
trudeau1111
- BMX
OK, what i did was drill out the faulty stock petcock, install inline filter, and shutoff valve. test run.........scoot runs good.
