99 sa50
t8kinover.
99 sa50
Post by t8kinover. »
hello,
i have a corsa bore i am thinking about installing in my 99.
i have 9:1 gears, high speed vari, sef ramp plate, assorted weights, aftermarket (i dont kno what it is called) i think it is a 1000 rpm clutch spring that adjust the width or the rear pully.
i also have a 28 mm carb with intake.
i had plans of doing a full build. i did not want to start it till i had everything. i needed a cht guage and some jets.
i am not new to scooter tuning just been a while. so my question(s) are ( i plan on buying a cht first) but i want to install the corsa with a stock intake (jetted) uni filter, stock exaust. would that be a bad idea to install?
any sugestions with that?
i could use the 28 mm carb (trying to aviod buying jets for it)
and i want a smaller carb
Re: 99 sa50
This thread is moved for reason: Technical questions should be posted to Performance Technical thread rather than Builds. The builders are over in this thread too.
[Performance Technical] - Does your Spree/Elite already run great, and you're trying to make it quicker/faster? Need a monster motor swap? Discuss your ideas here.
t8kinover.
Re: 99 sa50
my bad :coolcruise:
Re: 99 sa50
Post by eliteguy50 »
Jetted stock intake and exhaust is fine. 28mm carb is big for 72cc.
t8kinover.
Re: 99 sa50
:peace:
t8kinover.
Re: 99 sa50
what size jets should i start with?
uni filter installed.
scottinscotty
Re: 99 sa50
Post by scottinscotty »
Sell me your corsa!
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
Re: 99 sa50
Not using the 28mm because you dont want to buy jets :crazy:
You will have to get jets for the stock carb too.
eliteguy50 wrote:28mm carb is big for 72cc.
A 28mm carb would be better than a stock carb.
Why not just build it? you already have all the parts.
9:1 gears will be too short for a corsa :imo:
If you like to wheelie, or drag race......9.1's are good.
Re: 99 sa50
The stock carb would help choke it down for the gears.
Re: 99 sa50
eliteguy50 wrote:The stock carb would help choke it down for the gears.
The stock carbs pilot jet would supply very little gas/oil to cool the over reving 9.1 gears.
I would buy some jets and tune the setup you already have.
veedubh20
Re: 99 sa50
Post by veedubh20 »
28mm carb work well on corsa. It not because carb to big, some dont know how to tune that why noob.
48-142
18mm mikuni vm carb work well on stock airbox and s pipe.
t8kinover.
Re: 99 sa50
Thanks for all the replys everyone I did install the corsa I'm running a 98 jet stock carb.
I have not ran it much though and do understand the pilot is small it worries me.
I was going to buy some bigger jets.
Should I Just install the 28mm 130 main with about a 50 pilot.?
I try to keep it out of the idle circuit jet flow when I run it I'm in the habit of not closing the throttle after wot runs on the stock bore
evilone
Re: 99 sa50
Post by evilone »
t8kinover. wrote:Should I Just install the 28mm 130 main with about a 50 pilot.
55 pilot and 138 main is a better starting point
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Re: 99 sa50
For ease of tuning, the OKO 24 and 26 are available at the same price as the 28 at Treatland.tv. About $80 or $85 with shipping. Either one will work better in the low end and I'm not sure a Corsa can use the 28 without a really big pipe. There simply isn't enough demand for fuel, even at the 10.5K RPM mine runs, for a carb that big. Your mileage may vary.
Re: 99 sa50
a 28mm carb will work with even a stock exhaust.
