84 aero 50 help
ktvAERO
84 aero 50 help
Post by ktvAERO »
hi, im new to the forum. i was just asking if anyone knew any mods for 84 aero 50s. mine goes 37-38 ┬▒ 2. i just wanted to know how to get those extra couple mph's. like 40-41.
thanks
84' aero 50
Re: 84 aero 50 help
Post by eliteguy50 »
MachiniMachini the head for high compression should help. Porting will achieve higher RPMs that translate to more speed (assuming the belt drive is maxed)
Re: 84 aero 50 help
The '83 & '84 Aero 50 are a bit of an orphan. They have a 12mm carb instead of the 14 mm carb on all the other 50 cc scooters and the cylinder and block, bore and stroke combo are also orphans. The list goes on. Cutting the head .020" to .030" is one option. Changing the carb is a possibility or swapping to a newer motor is another. Going to a 2.75X10 rear tire is another. New belt and degreasing the variator will also help.
mmeadows
Re: 84 aero 50 help
Post by mmeadows »
ktvAERO
Re: 84 aero 50 help
Post by ktvAERO »
Bear45-70 wrote:The '83 & '84 Aero 50 are a bit of an orphan. They have a 12mm carb instead of the 14 mm carb on all the other 50 cc scooters and the cylinder and block, bore and stroke combo are also orphans. The list goes on. Cutting the head .020" to .030" is one option. Changing the carb is a possibility or swapping to a newer motor is another. Going to a 2.75X10 rear tire is another. New belt and degreasing the variator will also help.
thanks Bear, i got the 2.75x10 tire a couple days ago after i got a flat. works nice but no speed gain. i will try to degreasing the variator. would you recommend a kevlar belt? or is it just a waist of money. so you would just take some basic grease remover to the vari? just to double check, this is the vari...
84' aero 50
Re: 84 aero 50 help
That is the ramp plate. It goes on the back of the variator. The variator has the channels that the rollers roll in.
ktvAERO
Re: 84 aero 50 help
Post by ktvAERO »
this then?
vari 2.jpg (38.41 KiB) Viewed 5721 times
84' aero 50
Re: 84 aero 50 help
That'd be the variator casting, or "Drive Face" in Honda-speak. A spectacularly clean and unworn one, too. The '84 transmission is a bit of an Odd Duck, to the majority of us who own AF05 and later engines. I'm not certain if/how you can adapt the performance variators designed for the later engines into yours, but it's worth exploring.
Re: 84 aero 50 help
Wheelman-111 wrote:Greetings:
Last I read, a custom boss was needed.
ktvAERO
Re: 84 aero 50 help
Post by ktvAERO »
thanks for all the input. so does anyone know if a kevlar belt is worth the money?
84' aero 50
Re: 84 aero 50 help
ktvAERO wrote:thanks for all the input. so does anyone know if a kevlar belt is worth the money?
Not for a stock motor. It is harder on your engine and you don't need the additional strength.
ktvAERO
Re: 84 aero 50 help
Post by ktvAERO »
thanks forum
84' aero 50
