99 sa50
t8kinover.
Re: 99 sa50
Post by t8kinover. »
I ended up putting the stock air box on and drilled three eighth inch holes in it.
If I cover one hole with the finger it will four stroke during the midrange my idle is set a lil high and the mixture screw is set in between one and one and a half out. it seems to be running ok I really wish I had a temp gauge though
t8kinover.
Re: 99 sa50
well i have not blown it up yet! I was kinda hopeing to hear some more feedback on my carburator setup i put a piece of tape over one of the three holes. I guess it works fine i dont think it is running hot or has gotten hot. but i have put about a hundred easy miles on the bore. but i need to do something with my current sutup.
evilone
Re: 99 sa50
Post by evilone »
1 - 1 1/2 turns on mixture screw is pretty close. The air box shouldn't have any holes in it for it to run good though which could be another problem.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
t8kinover.
Re: 99 sa50
i would not run without the holes.. i put my stock motor back in
