Just asking
Re: Just asking
With the air flow restricted in the intake it would be similar to running smaller inlet ports. The engine would have good throttle response and low down torque but it would strangle the top end range. The more I read up on 2 stroke engines the more I realise how sensative they are to tune and set up properly...
- ILLEGALLIFESTYLZ311
- Goped
Re: Just asking
yes but im only going to 23mm from 17mm. my thoughts are that there wont me to much of a change in diameters
-90mph, 50mpg, still laughing?-
Re: Just asking
Do the math, 6 mm increase is a huge increase in area, which equates to a huge increase in air flow.ILLEGALLIFESTYLZ311 wrote:yes but im only going to 23mm from 17mm. my thoughts are that there wont me to much of a change in diameters
- Goped
Re: Just asking
okay well tell me a cheap carburetor i can put on since you know everything bear.
Re: Just asking
With your attitude, screw off.ILLEGALLIFESTYLZ311 wrote:okay well tell me a cheap carburetor i can put on since you know everything bear.
- Goped
Re: Just asking
That would require me to care. Which i do not. So, i will simply ask someone else
Re: Just asking
what gear ratio? you still have to premix cuz that bore runs hot, i would also buy a pipe.
Re: Just asking
There is an example of the help you are gonna get elsewhere. You really are too stupid to learn.maddog wrote:what gear ratio? you still have to premix cuz that bore runs hot, i would also buy a pipe.
- Goped
Re: Just asking
Yes i already run particial pre-mix in the stock engine now. Yes i already have a pipe for it Tell me your email so i can send you pics.
- Goped
Re: Just asking
also im gonna add im going to run 7.2 to one gear ratio
- Goped
Re: Just asking
Sorry bear about the smartass comments, But does anyone know of a carb the is cheap to put on a sa50
Re: Just asking
On the stock intake or on a CT?
- Goped
Re: Just asking
preferbly on the stock intake. i rly just dont want to fork out 200 bucks for a carb kit. i want one that can runn a 78cc kit and a expansion chamber pipe
Re: Just asking
To do it properly you need the CT intake, your stock intake and reeds (even aftermarket ones) will restrict any carb improvement you would get with a bigger carb.ILLEGALLIFESTYLZ311 wrote:preferbly on the stock intake. i rly just dont want to fork out 200 bucks for a carb kit. i want one that can runn a 78cc kit and a expansion chamber pipe
Taz sells an intake and 24 mm carb for the Spree and Early Elite that will work or there is this one on flea-bay.
http://www.ebay.com/itm/performance-Int ... 1291wt_952
- Goped
Re: Just asking
yea i was looking at this one which appears to be similar
http://www.ebay.com/itm/270662590619?ss ... 1438.l2649
Im buying all my other parts from him so i just id get that one and pay the extra price since ill get it alot faster.
