Drive belt question
- rkendrick429
Drive belt question
Hi everyone! I'm new to the forum and bike restoration. Can someone tell me the exact specs on the drive belt for a '87 Spree. Thanks
'87 Spree found molested and abused in front of a 17yr olds house
Re: Drive belt question
download the manuel
you can get it here on this website
i think its there ......
good luck
good luck
Honda part number 23100-GK8-870 sometimes 23100-GK8-8700 it is the same belt...Honda OEM is measured in mm but some people have posted one here about switching to a 1/2 inch top width/24" v cog belt but I haven't seen any reports about how that worked for those people. I got a brand new one on ebay last week for $5 syou can keep an eye out there, you can google 23100-GK8-870 or find them at the retailers listed on this forum here
http://www.hondaspree.net/phpBB3/viewto ... f=2&t=8049
1986 Spree
1986 Spree
1986 Spree
- rkendrick429
Buy the Honda belt.rkendrick429 wrote:didn't have any luck with the 1/2" belt kept killing motor if anyone has hint im open for suggestions i currently bidding on the correct belt but if anyone knows about a tougher one i can use let me know
I have tried all kinds of other belts and none work as well or last as long.
- rkendrick429
i found one at the honda place thats 26 dollars is there anywhere besides ebay to buy one cheaper?\
- stucinthe80z
23100-GK8-870 is the factory belt # mine lasted 1300 miles and this is with 300 miles of kib riding belts cost around 20 $ for factorybelt also check rollers if they are flat spoted it will not be gripe proper by ain pulley
good luck we have the remaining few the rest is sold in the e bay junkyard
My stock original belt has over 3500 miles on it and is still going strong.stucinthe80z wrote:23100-GK8-870 is the factory belt # mine lasted 1300 miles and this is with 300 miles of kib riding belts cost around 20 $ for factorybelt also check rollers if they are flat spoted it will not be gripe proper by ain pulleygood luck we have the remaining few the rest is sold in the e bay junkyard
BELT, DRIVE 23100-GK8-870 (replaces 23100-GK8-003) MSRP $27.78
My dealer gives me a discount, $19.25.
FYI the service manual say minimum width is 10.5 mm (0.41") while new is 11.5 mm (0.45").
The high horsepower Aero 125 says that you check the belt every 5,000 miles.
