Please Is this an '87 Spree Exhaust?
donut
Post by donut »
Bought an '87 parts spree with many of the parts loose.
The exhaust on my '85 looks fine, so I was thinking to sell the '87 exhaust.
but when holding it up to the '85 for comparison, it appears 'beefier"
On the backside there are notations including that it is a Honda Exhaust.
The exhaust reads HMGN2 Sankei 2091
Thanks in advance
'86 Aero 50 (NB50)
'01 Yamaha Jog Nextzone
donut
Re: Is this an '87 Spree Exhaust?
Post by donut »
Anyone have an '87 stock with the same markings?
If I sell this, I do not want to misrepresent it.
Thanks again
'86 Aero 50 (NB50)
abreen89
Re: Please Is this an '87 Spree Exhaust?
Post by abreen89 »
yea that exhaust does fit all spree years.
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
Actually Honda says different.
The '84 and '85 use the same exhaust. (18300-GK8-408)
The '86 and early '87 use a different exhaust. (18300-GK8-880)
The late '87 uses a different one. (18300-GK8-601)
Honda-san changed part numbers for any number of reasons, including different Outsource suppliers. Sometimes just for kicks, it seems.
Different part numbers notwithstanding, the '87 pipe should physically fit all years.
Since the later models seem to perform better, perhaps the later pipe represents an upgrade for an earlier one?
abreen89
Post by abreen89 »
i have an 87 exhaust on my 85 they are all the same just different numbers.
The '84 & '85 are different top ends from the '86 & '87.
Bear, "Different" as in different flange dimensions or location?
Wheelman-111 wrote:Greetings:
I would suspect the tuning is different because of the top end differences.
No doubt the header pipe differences are evident on inspection, based on pics I've seen. They started primitive and skinny, and grew fatter through the 4-year run. I'm also confident that the critical locations, flange angles and bracketry are all compatible. By that theory, the best pipe for modded Spree might just be one from an SB50 Elite ES.
Good theory.
The elite e pipe is the best pipe for the spree.
However, the sharp bend in the spree exhaust is there so that it will not bump the frame.
The E or ES exhaust may rub the frame a bit unless it is modded a bit..
geezer101
Post by geezer101 »
Warning, minor deviation in the thread here... I remember a tale of how, while Norton was testing one of their engines (I think it may have been the Commando), their test rig fell over accidentally and it bent the header pipe up near the mounting flange. When they uprighted the test rig, the engine made more power as a result of the pipe 'damage', so they set up their bending jigs to replicate the inadvertedly modded exhaust. I know, different engine etc... but maybe the principle is the same and the sharp bend you mention may very well be not related to the frame design but a deliberate move to extract a little more power? Back to the thread now... :geekdance:
z50r-ghost
Post by z50r-ghost »
That's definitely an '87 Spree exhaust... The '87 Spree exhaust "body" looks like the Aero 50 exhaust body.
If I remember correctly, the '84-'85 exhaust was the smallest, round type-
The '85-'86 was the "boxy" square looking muffler, and the '87 is the one in the picture above... I remember early in high school, i had an Aero 50 exhaust muffler welded to my Spree's header pipe. It *seemed* like it helped my little Spree have better top-end power...
Later, jon
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
donut
Post by donut »
Thanks for all the replies, so my '85 looks a lil better but it appears if I switch out to this '87 I might get a lil more "giddy up"...
Yes?
I'll post a picture of the '85 exhaust in case anyone is interested...
'86 Aero 50 (NB50)
Post by eliteguy50 »
The elite ES is the best top end exhaust for the spree.
