2001 elite contesa carbon problems.
spree picker
Post by spree picker »
72cc contesa,per mix klotz 32 to 1.21mm carb 95 jet,uni filter foam.v8 pipe.
I was riding one morning shut it off and tried to start it a hour later and it had lost compression.The rings were stuck in the piston .They seemed carboned up.Replaced piston and rings and rode it gently for about 2 tanks of fuel.
Went on a 5 mile ride shut it down to eat and the same thing happened.When I took it apart I found the same thing.Top of piston solid black from carbon and rings stuck again.
I could sure use some advice.
I give old Sprees a new life
Re: 2001 elite contesa carbon problems.
Sounds like cheap oil.
kingkamehameha
Post by kingkamehameha »
The more oil= bigger jets. Less oil in ratio=smaller jets. Did you do a plug chop to make sure you have the right jets? You could be running super rich. Try switching to a cleaner oil
spree picker
21mm carb with a 95 jet,and yes the plug looked dirty.
Mystic
Post by Mystic »
Are you using Klotz with castor oil? I was running super tecniplate at 32:1 and it made my rings stick too and light seized my bore. Needless to say I am not using castor oil anymore :P Racing oil is for racing since racing engines are not build for longevity go with a full syntehtic oil and you should be good. Just because the brand of oil is supposedly better doesnt mean it is correct for street applications.
spree picker
Yes sir
Mystic
Post by Mystic »
I had to learn the hard way :D I run Lucas performance in everything I have now and never had any problems. When I was running the super techniplate it seized and when I took the bore apart it looked like an old deep fryer with all the gummy oil stuck all over the piston. Like I said whichever brand you use try the full synthetic or even semi-synthetic without castor
spree picker
Same thing. 100 miles and its gummed up.
veedubh20
Post by veedubh20 »
just port and polish on the exhaust.. :wink:
