Aero 125 Rebuild Or Skelly?
DeathByFox
Post by DeathByFox »
SO my aero 125 kinda ran when i first got the scoot. It no longer will run. I thought it had a vacuum leak but im pretty sure i fixed that problem. Now it just wont start at all. I have an elite 80 to ride around so this has become a project scooter. Heres some pictures and questions.
102_3348 by SouthsideSaint, on Flickr
So i removed the break lock assembley. What else should i do?
102_3349 by SouthsideSaint, on Flickr
Is there anything i should do to this? Should i install a switch?
102_3342 by SouthsideSaint, on Flickr
You can just see the carbs gasket sticking out from the bottom. Would this effect running conditions? Any insight or help is apreciated. And if not anyone want some parts?
Bright lights put me in a dance But it aint house music makes me wanna dance
Re: Aero 125 Rebuild Or Skelly?
Not the stock carb, so without knowing the jetting, who knows.
Do a compression test first.
DeathByFox
Mikuni and 20 are the only things on the carburetor. Other then what looks a serial number. Why do a compresssion test?
DeathByFox wrote:Mikuni and 20 are the only things on the carburetor. Other then what looks a serial number. Why do a compresssion test?
These scooter came with a Keihin PA carb, hence the none stoke carb which as often as not are the problem.
Aah, it no longer runs and without compression all the fuel and spark in the world will not make it run.
If you know what you are doing, why are you here asking for help? Why the * are you questioning the advice?
DeathByFox
I was merely curious why thats something to check? And would putting an original carb on help at all?
DeathByFox wrote:I was merely curious why thats something to check? And would putting an original carb on help at all?
A compression check tells you about the physical condition of the cylinder, which is the heart of the motor.
With the original carb you would at least know it was jetted right. Going from an 18mm to a 20mm carb is a waste of money and looking for problems with minor if any increase in performance.
DeathByFox
Well the only problem with that is this is how the scooter was purchased. Any insight about removing that locking mechanism?
That's easy, remove the whole foot brake assembly and throw in the trash. Install a left hand brake off an Aero 80 and get a longer cable. Unplug that stupid switch and let it join the rest of that foot brake insanity. My 125's starts every time.
DeathByFox
Thanks. Now if my engine has no compression, im screwed arent i? I cant seem to find a cylinder rebuild kit online anywhere? Would it now require an engine swap if its toast?
Wiseco makes a piston that will work.
Search using
"1985 Honda CR125R"
c3maddox
Post by c3maddox »
I say go skelly and then sell me your right Sid cover.
Thanks
DeathByFox
So i removed that and now it wont crank at all. At first i thought it was that stupid foot lock. i reinstalled it up to were i could make it think it was activated/ deactivated. and it still wouldnt crank. I know the battery is charged and the key is in the on position. Also now when i step on the rear foot break it wont activate the break lights. Im thinkin i may have gotten in over my head with this scoot. Any advice is appreciated. Also looking to purchase a stock carb if anyone has an extra.
Peruse the wiring diagram in the service manual. It will help.
...what is SKELLY ?... :confused:
DeathByFox
To make it so that you see the skelleton(Frame) of the bike. I would basically ditch all the plastics and route the wires through the frame. install some foot pegs and go.
