Just asking
Re: Just asking
Different intake and too much carb which will make tuning a b**** and it costs a whole bunch more.
ILLEGALLIFESTYLZ311
Re: Just asking
Post by ILLEGALLIFESTYLZ311 »
hmm true... yea ill go with the one you gave me. Also will this variator help me at all? i meanm is it worth the money. I want to be able to go 65mph
-90mph, 50mpg, still laughing?-
Re: Just asking
A link?
ILLEGALLIFESTYLZ311
Re: Just asking
Re: Just asking
It is better than the stock variator.
Re: Just asking
Post by eliteguy50 »
The keli has a better midrange and usually yields 1-3mph increase in top speed.
ILLEGALLIFESTYLZ311
Re: Just asking
If my new carb has a single throttle cable, can i still have all of the oil pump "workings" still attached to the motor and just run premix? Or does one have to put a plug in the motor and ditch the assembly?
Re: Just asking
ILLEGALLIFESTYLZ311 wrote:If my new carb has a single throttle cable, can i still have all of the oil pump "workings" still attached to the motor and just run premix? Or does one have to put a plug in the motor and ditch the assembly?
FTW
ILLEGALLIFESTYLZ311
Re: Just asking
Is it possible to run it with the assembly still attached?
Re: Just asking
ILLEGALLIFESTYLZ311 wrote:Is it possible to run it with the assembly still attached?
yes
Re: Just asking
yes
But you are looking for a pump failure in the future which could ruin your crankshaft. Not the right way to approach this and plugs are cheap.
Re: Just asking
Those gears you chose may be too tall.
They are 6.5:1 on the af16
ILLEGALLIFESTYLZ311
Re: Just asking
i thought 7.3 gears would make it super quick on the topend?..unless i am mistaken?
Re: Just asking
ILLEGALLIFESTYLZ311 wrote:i thought 7.3 gears would make it super quick on the topend?..unless i am mistaken?
You are confusing your terms. Quick refers to acceleration and lower numbered gears do not help that.
Fast is top end or speed and low numbered gears make you fast if you have the horsepower to pull those gears.
In drag racing quick is your Elapsed Time and MPH is how fast you cover the distance between the traps at the end of the 1/4 mile. The slowest guy, mph wise can actually win the race by being quicker, having a lower ET.
But in any case you have to have the horsepower to go fast or all the gears in the world will not make you fast.
