hi forum:
if i were to swap my 12mm 84' aero carb for a 14mm 85'-87' aero(or any other honda 14mm carb?) what would happen? and what would i have to change for it to run properly?
thanks
ktv
carb swap
Re: carb swap
It will work and probably without a jet change. But the power increase will be minimal and may well take a GPS to see the difference.
Re: carb swap
ktvAERO wrote:thanks. do you know if it will fit the same as the 12mm?
ktv
Bear45-70 wrote:It will work and probably without a jet change..............................
