Honda Elite SE50 (split from build thread)
mmeadows
Post by mmeadows »
Bear you had a aftermarket exaust forsale :cry: ?
looking forward to pictures.
martynkim
Re: 1987 Honda Elite SE50 Build
Post by martynkim »
I suggest that you buy a roller tuning pack from Daywot. Find the sweet spot and then replace them with some good rollers.
martynkim
Post by martynkim »
Don't forget to have .050 shaved from the head. Adds compression and torque. A good 5 mph add.
zuphilius
Post by zuphilius »
Thanks for the heads up, so to speak. I'm thinking getting a different head so I can go back to stock if need be.
Where or how would you shave the head and how much? Sandpaper on a flat surface?
martynkim
Post by martynkim »
zuphilius wrote:Thanks for the heads up, so to speak. I'm thinking getting a different head so I can go back to stock if need be.
Have it machined. It needs to be flat. Dont try to DIY.
bradthreee
Post by bradthreee »
I've seen it done on a flat piece of marble and some type of paste
zuphilius
Re: Honda Elite SE50 (split from build thread)
Post by zuphilius »
Got my Ruckus variator installed then discovered a flat tire. I will get that taken care of tomorrow and then I will take it for a ride and report back.
zuphilius
Post by zuphilius »
Went and got a new tube, as the one in there looked very old and nasty.
Finally got it back together, went for a ride. I have all 8 grams in the Ruckus variator, it is slow off the line, then gets up to about 30 up a slight long uphill, seems to cruise at about 35, pegs out at 45 downhill.
So, what's next? Heavier weights to get more top speed? Lighter weights to get quicker off the line? Clutch spring? Just put the LV on (and do I need to upset for that?) to see what that does? Lose 40 pounds?
Seems my performance decreased with the Ruckus variator from stock, but faster down a hill. Problem being, it seems to be uphill both ways every where I go around here.
Engine runs great, no problems there.
Any suggestions would be great.
mmeadows
Post by mmeadows »
why are you waiting to put the exhaust on? let me know how much of a perofmance increase it gives you. vs the stock pipe.
also where did you find a tube to fit that tire. every tire place i went to here in portland ( americas best, lesswab) said they could not find it. i finally broke down and filled it with fix a flat because i really wanted to ride my scooter.
zuphilius
Post by zuphilius »
I'm trying to do things a little at a time. I'd like to get the variator tune a bit better before changing out the pipe.
The tube is a 3.00x10, got it from a local scooter shop.
paulpauly7
Post by paulpauly7 »
only problem with that is your tuning your variator for the stock exhaust when you put the new one on it may have a different rpm powerband which means you will have to retune the vari again :thumbwink:
mmeadows
Post by mmeadows »
maybe because my shops were looking for a 2.75 10 they coundt find it, but still id think they would have offered.
im not positive but from what i read your engine will act different with the pipe ( especially how quick it revs up) so once you change the pipe you will need to change your weights again.
this is second hand knowledge though, i don't have an aftermarket exhaust.
how much do you weight? im 220 and get about 35-38 on a wot cruise around town ( just a rukus variator upgrade)
i would suspect that with your 10:1 gears you would be faster than me.
hows your belt? my roommate who is upgrading his se50p swapped his bet out yesterday and i notice is being much more responsive off the line and a much smoother acceleration to top speed. not sure if it helped top speed though as his spedo is broken.
how are you measuring your speeds?
when im trying to increase my top downhill speed, i just find a bigger hill :coolcruise:
paulpauly7
i have a af05e with a lightly ported malossi bbk and head from red eft a ported block CT crome 24mm oko 44pilot 104main high speed pully kit 6x5g rollers 17mm wide belt 10:1 gears 3.00 by10 tyre and a high reving expanshion chamber pipe from japan and it will do 55mph maybe a bit more if i held WOT longer
mmeadows
Post by mmeadows »
that's a pretty sweet set up.
zuphilius
Post by zuphilius »
Looks like if I change the pipe I need to upjet to a 88 or 90. I need to get some jets from someplace before I change it out.
I tried all 6 gram sliders and didn't like the way it revved up and also the low top speed.
I work tomorrow so I don't think much is going to get done, Sunday and monday everything is closed. So I guess it doesn't get much work done over the next couple days.
Story of my life.
