Cleaning a clutch
Spreeboy7118
Cleaning a clutch
Post by Spreeboy7118 »
Is there anything to use to clean a clutch? I know that pads are sensitive to grease and such. Would brake cleaner work?
86' Spree
Re: Cleaning a clutch
Why are you cleaning your clutch?
SpreeBoy is fastidious. Brake (but NOT carb cleaner) is designed to leave no residue and should work to clean the pads and drum of the offending dust. Now I have to resume dental-flossing my tire treads...
Spreeboy7118
I just like to keep things all good. I figured since I had it apart I might as well clean it. :smile:
86' Spree
