I'm also thinking of ordering up one of those vapor displays that show rpm, mph, engine temp. Kinda a cool little display, if I get crafty maybe I can build it into the dash of the elite.
But is their 82cc setup make as much power as a corsa bbk?Bear45-70 wrote:VT Cycles says "Now on a OKO 24mm, we jet the carb on a 82cc Dio set up with a performance sport exhaust at #115 to #120 main. The Pilot at #40 to #45."
What has that got to do with it? This is a starting place, not the end result of proper jetting.steffen707 wrote:But is their 82cc setup make as much power as a corsa bbk?Bear45-70 wrote:VT Cycles says "Now on a OKO 24mm, we jet the carb on a 82cc Dio set up with a performance sport exhaust at #115 to #120 main. The Pilot at #40 to #45."
Lets say somebody suggests a jetting for a real * (makes no power) bbk, and you use that jetting on your super awesome high HP producing BBK.Bear45-70 wrote:What has that got to do with it? This is a starting place, not the end result of proper jetting.steffen707 wrote:But is their 82cc setup make as much power as a corsa bbk?Bear45-70 wrote:VT Cycles says "Now on a OKO 24mm, we jet the carb on a 82cc Dio set up with a performance sport exhaust at #115 to #120 main. The Pilot at #40 to #45."
Perhaps i'm way wrong, but a 145 is way more than a 120. Do you really think during break in, you need that much more cooling effect?veedubh20 wrote:better start of bigger jet 52/145.
alimunum get heat expand dont go more than half throttle.
You sir, are DUMB.zuphilius wrote:From what I'm reading, Bear offered 115-120 main, you came back with that seems way too small for your application. Veedub offered 145, you say way too big.
IMO you need to step back and weigh the input you're getting, instead of not liking any suggestion from the gurus on here. They are not setting you up to fail.
If you are such an expert on this jetting thing, why the H%LL are you here asking for advise?steffen707 wrote:You sir, are DUMB.zuphilius wrote:From what I'm reading, Bear offered 115-120 main, you came back with that seems way too small for your application. Veedub offered 145, you say way too big.
If you take the first piece of information somebody gives you with blind faith, you are going to fail in life. Bears suggestion was from vtcycles based on their 82cc kit, my only point in that I didn't like bears suggestion, was that it wasn't for a corsa with 24mm oko and a pg long, it was with vtcycles bbk(whatever brand they sell) and a sport exhaust.
I know others like wheelman have used the same exact setup that i'm going with, so i was hoping to hear some people chime in. After sifting through all of wheelman's flash 3.2(i think) build I found he liked somewhere around the 50pilot and 120main, I consulted with bakaracer, and he suggested the same exact thing.
Of course i'm not going to just jet it and forget it, I'm going to do as wheelman suggested and do plug chops and watch my temp after i get my trailtech vapor installed.
So really i only disagreed with veedubh20 without much explanation that 145 is way too rich. And i'm basing that on knowing what bakaracer, wheelman, bear have all suggested.
Yeah, pretty much, the experts give you numbers like you asked and you told them all that they are wrong. Real good way to get more help.steffen707 wrote:I didn't say i was an expert bear. And i think i've explained myself pretty well.
