DD50 corsa
Downsouthdio
Re: DD50 corsa
Post by Downsouthdio »
Thats crazy high comp.. You may end up with 3 gaskets. I have 2 to get mine at 125
Honda super dio
Corsa
26mm
Sparrow
veedubh20
Re: DD50 corsa
Post by veedubh20 »
well, I dont have trouble using polini gasket base and oring head gasket. :coolcruise:
I dont play on compression ratio gaskets. :mrgreen:
Downsouthdio
Re: DD50 corsa
Well i dont wana fry my engine either , i can pull more power out of it
Honda super dio
Corsa
26mm
Sparrow
kauaianman
Re: DD50 corsa
Post by kauaianman »
added head gasket again. compression now 120-125.
motor still running hot.
I have since put hondabon with the base gasket to ensure no leaks.
I'm starting to think it's the cylinder.....
like i said the piston sits a good 1mm below the exhaust port on the bottom stroke. maybe when the exhaust port is all the way open the 1mm bottom lip is causing bad airflow out of the exhaust.
this is the first cylinder that i put in that sits below the exhaust port.. they are all usually dead flush with the bottom of the exhaust port.
I seem to have tried everything with this block. don't know what to do next.
going back to stock carb and mani. soon. just to try
kauaianman
Re: DD50 corsa
kingkamehameha wrote:Crank needs to be taken out anytime that you do port work. If your compression is at 155 you will blow a hole in your piston with the pump gas
only did very minor port work and only on upper portion of boost port. i just soaked some rags with oil stuffed them in the crank area, flipped the block upsidedown, and used a small file and very frequently wiped out all the filings as much as possible.
Corsa boost port not much bigger than stock so not much to clear.
tru72
Re: DD50 corsa
Post by tru72 »
thats not porting ...
boost port helps in cooling the motor as well...
kingkamehameha
Re: DD50 corsa
Post by kingkamehameha »
Boost port needs to go straight down thats why the case needs to be separated an crank taken out. I doubt your getting hot because of that. You need to do a correct pressure test on your motor and then get back to us
kauaianman
Re: DD50 corsa
thanks for the advise.
i usually cutr the boost port straight down. i was lazy and just wanted to clean up the top a little.
still working on making a pressure tester.
i dont think an intake leak is causing the heat because wheni soak the intake (the entire intake) with carb cleaner i get no change in idle at all.
i would think a manifold leak big enough to run the bike lean would be found with some carb cleaner.
and the weird thing is the plug shows no signs of running lean.
kauaianman
Re: DD50 corsa
the other day that minor leak on the boost port was bothering me so i pulled the head and put hondabon on with the aluminum base gasket.
sopme pics
kauaianman
Re: DD50 corsa
made sure hondabon was even all around.
kauaianman
Re: DD50 corsa
after putting the hondabon i used only original corsa O-ring head gasket and got 150psi compression
tried it out and ran hot so i pulled the head again and used a regular size head gasket with the corsa O-ring and compression came down to 120.
still running hot.
no leaks comming from base of cylinder at all.
kauaianman
Re: DD50 corsa
yeah i kno.... sad for me to call that porting at all... more like minor clean up. i though maybe it would help a little.
my friend running same setup with no porting at all on hisd dd50 block and bike run good. 250-270 degrees cruzing under 35mph. all bolt on no adjusting/tweaking anything.
veedubh20
Re: DD50 corsa
Post by veedubh20 »
what oil did you use and gas?
Downsouthdio
Re: DD50 corsa
Check your shrouds, make sure they are snapped together, you running the plug that came with the corsa?
Honda super dio
Corsa
26mm
Sparrow
kauaianman
Re: DD50 corsa
using shell V-power gas. redline oil. premix 3.5oz per gal.
all cooling/engine shrouds are good and tight. i use NGK B8hs plug.
pulled the manifold last night and found leak at base of manifold.
tested base of manifold and it doesn't sit perfectly flush with the block. I gotta find a belt sander and try to get the CT back as flat as possible so there is good contact between the manifold and the block.
any good ways to do this?
i cant imagine that i have the only CT manifold with this casting issue.
